Engine not in time??
So a week or so back I was driving 4th gear cruising and my car just shut off, ran codes and it said cmp sensor intermittent so we are inside doing the timing belt and sensor and we can't get the engine in time, when the cam gears are TDC the crank gear is at 5 o clock I'll provide pictures to have a look, note both the cam gears are at tdc but the crank gear isn't, when the crank is at tdc the cam is on cylinder 6 and 2, is it possible that it really jumped that much and why would the two cam gears still be in time with each other
Check the tensioner, sometimes they will fail and allow the belt to jump a few teeth since there is no tension on the belt.
Pair of TLs (03-29-2022)
I would guess that because the crankshaft supplies the force to the belt, it will always be easier for the belt to slip at that point. The cams only receive force from the belt.
I still can't figure out how your engine is off 9 teeth with no loud noises.
Update
Was able to remove all timing components and put the engine in the correct time, tomorrow we will try to assemble and test everything, also a update on why it jumped we may have found the reason, the lower tb cover seems to almost be shredded around the crank pulley area and I'm assuming a piece of plastic got stuck between the belt and gear🤷♂️
Check the crank pulley make sure the rubber isolator hasn't split letting the pulley move around side to side. When they fail they usually come apart and slide with the center section still attached to crank.
Best of luck with the engine.
redbeard1 (04-01-2022)
It does seem as though the crank pulley was rubbing against the cover. Maybe at the last timing belt, they over-tightened the crank pulley nut thereby forcing the pulley closer to the cover. One other idea, any chance were you missing the spacer/shim shown in the attached image? If that spacer/shim was missing, I imagine the pulley would be tightened too close to the cover.
Update #2:
Was able to get everything back together and in time today, we started it and there was a loud audible tick coming from bank 2, I guess I wasnt so lucky, we did a compression test on #4 and #5, #5 clocked in at 0 for compression I'm assuming that one of the valves is toast, that's as far as we could get today till Monday where we will do a leak down test to confirm what we found and then probably pull valve covers and go from there
That's the outer ring of the crank pulley! The inner one that bolts to crank was still attached to the block and this came apart! Have seen a handful in my year wrenching.
Update #3
Did leakdown test today and cylinder 4 held some pressure but by no means good and cylinder 5 really did nothing, so I'm left with two options pull the engine and get a lower milage one or take the heads off( almost there already with timing belt 2 bolts away from being off and valve covers off) and rebuild them, my only question is if the valves are bent does this mean possible the rockers are going to be bent, everything I've seen shows rockers are $$$$$$$ is there a tell tale way to really tell or are you just looking for deformities
cristian102
11-26-2021 11:04 PM
dallison
03-07-2007 03:07 PM
