electronic auto start
Old Jul 30, 2004 | 12:00 PM
WlcTL's Avatar
hi everyone i was wondering if any1 know about auto start stuff. i believe there are 2 types od auto start?? 1 thats electronic and the other where they hide the key inside or something??? plz fill me in. any if any1 knows a good place around boston plz help out thank you all....
Old Jul 30, 2004 | 12:04 PM
Ron A's Avatar
Administrator
Do a search on "immobilizer". There are several threads there that will give you some info until someone with more knowledge about this subject replies.
Old Jul 30, 2004 | 03:10 PM
I'm Batman's Avatar
Boom goes the Dynamite
You are slightly confused. On cars that have factory immoblizers and want to have remote start a bypass module is needed. This is were a key might be needed.
Old Jul 30, 2004 | 07:05 PM
Road Rage's Avatar
Not a Blowhole
What is the purpose of doing a remote start? it is not good for your engine to have it idle for long periods, especially in the cold, because unbuirnt fuel will wash past the rings and cause fuel dilution of the oil. It can also result in increased upper cylinder wear.
the best thing is to start your car, give it 15-30 seconds tops to let the oil pressure stabilize, then drive off, driving moderately for the first 15-20* minutes. It takes about that long for the oil to reach 200 degF, which is when the anti-wear additives in the oil begin to be most effective.
*that is for summer temps - it can take longer in very cold climates. The 5AT cars warm up faster because of the heat exchanger in the tranny which uses engine oil to cool its lubricant.
Old Jul 30, 2004 | 10:07 PM
taschroth's Avatar
Its like a microwave, once you have it you will understand and can't go back! Getting in a cool car in the summer and warm car in the winter. Sure idling for 10 - 20 minutes... somethimes, usually just 30 sec to 1 min as you walk to the car. I will only buy cars with an AT and auto climate control so as to work well with remote start.
DEI owns the market, Viper, Python, Valet, all made by DEI. You want to spend the $$$ and get a two way remote (so you know the car has started)
rockyboy
Aug 4, 2024 10:35 AM
obert
Dec 14, 2015 11:36 PM
Sep 14, 2015 10:48 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
