DRL switch hack
7th Gear
DRL switch hack
Can anyone send me a link for adding an on and off toggle switch for my drl lights? Seen it and asked how they did it with no response, so I'm hoping someone on here can reply with a link.thanks in advance
From your relay harness add a wire from the + all the way to the cabin. Then use a "add a fuse" and crimp another wire to that. Connect the wire you ran from the harness and the add a fuse wire to a switch and you're good to go
EvilVirus (09-01-2014)
Welcome to the forum. ![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
The forum where you originally posted, The AcuraZine User Help, Support & Suggestions Area , is meant for problems, comments, and suggestions for the website itself, so I moved your thread to the car specific forum applicable to your vehicle.
7th Gear
Appreciate it. Will that give me full control where I can turn on a night also?
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SUPRMN84
10-07-2015 09:46 PM
xsilverhawkx
09-28-2015 06:51 PM
