DRL L.E.D. Mod
Old Jun 10, 2007 | 03:07 AM
  #121
MMJK84's Avatar
yeah 'whatever floats your boat'...I wouldn't go that far with LEDs...it just makes it look like a spaceship...but like I said, whatever makes you happy, it's your car...
Old Jun 10, 2007 | 12:35 PM
  #122
Buda's Avatar
Starcraft II addict
I'm going to test putting them up front just to see fitment and to let others see how this type of LED will work. I will most likely end up putting these in my trunk for lights there. These would work great for that as they won't stick down like the cold cathode lights.
Old Jun 10, 2007 | 05:34 PM
  #123
Buda's Avatar
Starcraft II addict
Here are the LEDs on the car. The center bar is thinner, however it could still be flattened, the LED strip 3Med on and then maybe put a small bead of silicon behind the strip where it goes above/below the center strip. Just a thought.
I'll see if I have time to get a couple of night shots tonight. If not I'll do them tomorrow.
DRL off:
DRL On:
LED strip is on left side. It is easier to see at this distance then it shows in the pic.
DRL chopped to be on both sides. Right side is chopped from same shot with LEDs on right:
Old Jun 10, 2007 | 07:47 PM
  #124
bigb252's Avatar
Loving this thread.
With the post above mine - what's the red wire seen right behind the grill?
Post some night shots when you get a chance!
Old Jun 10, 2007 | 11:33 PM
  #125
Buda's Avatar
Starcraft II addict
There is also a black wire hanging down as well. It was just to give power to the LEDs from the battery so I could take pics. I didn't fully install them. Just 3 small pieces of 3M tape to hold them on temporarily.
I was planning on getting some night pics taken tonight but I just got home and am exhausted. I'll take some night pics tomorrow.
Old Jun 11, 2007 | 03:52 PM
  #126
tehloxely's Avatar
Hrmm... I don't know if I'm lovin it. The leds are spaced too far apart. And maybe not bright enough. Just my 2c.
Old Jun 11, 2007 | 04:03 PM
  #127
fant0m_TL's Avatar
Pimpin' Ain't Easy!
you know what i think would look hot... is if you did this backwards... sot hat the leds are facing the other side, that way you dont see the actual bulbs/lights coming from the front, but you see the hue/glow inside the grill... might look
might be asking a lot, but if you get a chance, could you do this backwards? or did i just sound like an idiot and not type it well enough to make sense lol
Old Jun 11, 2007 | 04:16 PM
  #128
Buda's Avatar
Starcraft II addict
^-- You mean having the LED strip placed on top of or below the center bar so that the light shines up/down respectively to illuminate the grill area? I can try to play around with that tonight.
Old Jun 11, 2007 | 04:17 PM
  #129
Buda's Avatar
Starcraft II addict
You may be right on that part. However I think for night use they would be more appropriate.
Old Jun 11, 2007 | 04:22 PM
  #130
fant0m_TL's Avatar
Pimpin' Ain't Easy!
sorta... i was thinking more along the lines of when the LEDS are facing OUT, that you put the on the other side of the grill so they re facing in... creates a glow affect... kinda like the car in the movie... but a lot more subtle but enough light/glow to draw attention.
Old Jun 11, 2007 | 04:29 PM
  #131
Buda's Avatar
Starcraft II addict
Ahh I get it now. Not sure if that will produce much light at all as the strips are pretty flat and mounting the strip with the LEDs against the back of the grill could cause not much light to get past. Mounting would also be a problem. I'll see about trying that as well as putting them on the rear of the grill facing inward toward the engine bay.
Old Jun 11, 2007 | 06:12 PM
  #132
rockyfeller's Avatar
King of NYC
Definitely looks cool. You will always get that "what the freak was that??" reactions by passerbys.
Problem is I doubt this will serve a real DRL function if that was your goal. It looks more like an accent light rather than a visual safety device. These will be very visible at night but hardly in the daytime. DRL headlights will fare much better. Otherwise you have to go for a high mcd LED option like the ones Audi uses. I doubt they are using mini-SMT LEDs.
Old Jun 11, 2007 | 07:44 PM
  #133
Kennedy's Avatar
OMGWTF4THGENTL
If you're into the "neon underglow" thing, also known as "puddle lights" today... Line the bottom of your blody kit with those strips.
Lots of neat options there. I'm definately getting a set of those in blue to replace the little blue led clusters I'm using for interior accent lighting.
Old Jun 11, 2007 | 08:11 PM
  #134
Buda's Avatar
Starcraft II addict
Yeah those strips definitely have some uses and with how thin they are it makes keeping them out of the way very easy. I was thinking about the interior with these as well. Especially if the light output is less than the cold cathodes. I want accent lighting. Not daylight.
Oh yeah, when I ordered this I only purchased the 12" one but they sent me the 24 inch (2 x 12). You can also cut the strip in 3 places and it will still work.
When it gets darker I'll get those night shots.
Old Jun 12, 2007 | 12:21 AM
  #135
Buda's Avatar
Starcraft II addict
Night "shots"
So pictures just were not giving the right results as to what it looked like so I got out the camcorder.
http://img532.imageshack.us/my.php?image=drlci9.flv
Old Jun 12, 2007 | 12:37 AM
  #136
sandiegodrive's Avatar
Back after 1 Year!
Hey thanks for all the different view points
Can't wait to see it when its all in place!
Old Jun 12, 2007 | 08:16 AM
  #137
fant0m_TL's Avatar
Pimpin' Ain't Easy!
hey thanks a lot! that grill light looks sweet! I want to somehow figure out a way to make that grill light up like in that video, but hit the strips/bulbs... hmmmm lol
Old Jun 12, 2007 | 09:19 AM
  #138
lyk3n0other8's Avatar
EBAYGEEK
I just ordered mine =]
I'm not so good on installation.... Anyone can do a small write up ? Thanks
Old Jun 12, 2007 | 01:56 PM
  #139
tehloxely's Avatar
OK well they look good for night use only. I wouldn't put them on the front bar though. I would embed them a bit more in (since the strip is black).
Also would you show us a show with the headlights on?
Old Jun 12, 2007 | 03:22 PM
  #140
Buda's Avatar
Starcraft II addict
^-- I'll see about taking a picture or a small video with my camera tonight.
Old Jun 13, 2007 | 05:36 PM
  #141
EBAYGEEK
Installation Process write up please
Old Jun 13, 2007 | 06:37 PM
  #142
Buda's Avatar
Starcraft II addict
I haven't done the installation on the ones that I got. I have just temporarily mounted them to try out different spots. I'm still not sure what route I'm going to use. However I think sandiegodrive did a write up on his install earlier in this thread.
Old Jun 13, 2007 | 11:04 PM
  #143
Buda's Avatar
Starcraft II addict
Ok guys, I have another idea about that center bar and the LEDs for the day time. Sandiegodrive, how thick are those LEDs that you installed?
Old Jun 13, 2007 | 11:07 PM
  #144
Buda's Avatar
Starcraft II addict
One thing I can suggest on the install is that make sure you use silicon on any areas around the connections. Even though the LEDs are weather proof, the connection points are not.
Old Jun 14, 2007 | 01:50 AM
  #145
Back after 1 Year!
Old Jun 15, 2007 | 04:20 PM
  #146
EBAYGEEK
I just got, mine great size, you can really hind them any where.... I dont know how to connect them anyone can help please do thanks
Old Jun 15, 2007 | 05:00 PM
  #147
Buda's Avatar
Starcraft II addict
By connect them, what do you mean? Connect up power, connect to each other, attach to car, or run wire to switch inside the car?
All of this really depends on where you want to put them and how/when you want them to come on.
Old Jun 15, 2007 | 05:58 PM
  #148
EBAYGEEK
I want to place it under the grilll
Old Jun 15, 2007 | 06:10 PM
  #149
Back after 1 Year!
Looking forward to see how they'll look
Old Jul 21, 2007 | 11:52 AM
  #150
100%Belizean's Avatar
WHT-on-BLK
Originally Posted by sandiegodrive
Well I finally got the lights on with the help of Sun Diego CL-S and they look great!
Sun blazing and you can call these D.R.L.
We drove down the street and people driving the other way had the "what is that?!" look on them
Sun Diego CL-S will upload more pics shortly. Until then I'm waiting for the Sun to go down a bit and then night time pics too when these lights will really shine
What are the lenght of the lights that you used?? Materials needed?? Thank you.
By the way, the whip is looking nice.
Old Jul 21, 2007 | 11:54 AM
  #151
WHT-on-BLK
Originally Posted by Sun Diego CL-S
Ivan. the pics you posted look great but don't do this mod justice. they look great in person.
after we removed the bumper, we pulled both lower grilles from the bumper and cleared out some bars in order to have one clean slot for the LED strip.
here you see Ivan using the Dremel to make everything flush and even.
grille without and then with strip.
i wasn't so sure about using this stuff for the install, but it was easy to maneuver and really holds tight!
this is after the glue application and placement of strips. they are splinted in place while the glue dries.
talk about haywire!
this is the switch that was chosen.
finished product looks great even when not rolling.
Can you repost the last 4 pics. They aren't showing up. Thank you!
Old Jun 14, 2009 | 08:26 PM
  #152
808origin-al's Avatar
ppsssshhhhhhhhh
looks too flashy for my taste. I like the clean and simple look. just my no hate!!!!!
Old Jun 15, 2009 | 10:07 AM
  #153
xziler8's Avatar
5th Gear
These guys actually have a nice product...
http://www.oznium.com/led-flex-strips
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
