Drl Bulbs
Originally Posted by 07 TL TYPE-S
Can you change your Daytime Running Light bulbs to white / blue ones?? if so whats the bulb # ?
K.
K.
I tried all day to do it without the warning light coming on but I cant figure out a way short of taking apart my dash and disabling the warning light bulb as well. So I just ended up with sticking to leaving the DRL fuse out. It says DRL on my dash but its small and not bright or anything so I dont mind.
I Install A Set Of Hid. They Look Amazing.it Kind Of Tricky To Istall,because The Amount Of Voltage Dlr Use It's About 5v And You Need 12v To Trigger The Hid On. I Had To Use A Special Relay Just To Get Ot To Work.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
ripit
09-26-2015 06:19 PM
