Driver's Door Security LED HELP!!!
hi everything, can anyone scan in some pages from the service manual for a 3G TL on the security system? my LED on my driver's driver's door is constantly on no matter what. can someone scan in the pages or email me those pages on teh factory security system and how to trouble shoot it? thanks in advance.
I've been through the service manual, and there is nothing mentioned about when the light is on all the time. There are way too many pages to scan, and since there are no instructions for checking out a constantly on light, they probably wouldn't do too much good.
You can pull the door panel and check the wires going to the light unit, and the connector they plug into and see if you have a constant ground and a constant power, which is what would make the light stay on. It's possible the light unit is defective causing the light to stay on.
Sorry about not scanning everything you might need, but I only have a basic printer and have to scan everything manually and then process it so it will upload, and I don't mind doing a few pages at a time, but this is a lot of pages.
yes i have check, there is constant ground and constant +12v on that wire making it constantly stay on. that is why i would like to see where those 2 wires lead to so i can check that unit if possible.
thank you.
thank you.
BoricuaTL
04-08-2016 01:08 PM
