Door mirror's tilting
ok guys, i know that when put in reverse the door mirror will tilt to view the curb, but what i found pretty odd today is when i backed into a Snowy parking spot after my right door mirror tilted as the tire started to lose traction and the VSA starting kicking in, the mirror kept moving back n forth on it's own, like n up n down, constant movement, is this normal??
i mean i dont mind it it might come in handy i guess to kinda see where ur goin better??
The mirror will quit tilting once a upper speed is reached. I live in a neighborhood where sometimes its easier just to back up 100 ft then try to get turned around. Once I reach something between 10-15 mph backing up the mirror moves into its normal position until the speed reduces and it tilts once again. I assume "the engineers" figured that if you were going that fast you'd want to see what's behind you, not what's by the curb.
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
