Door Lock Button
Old Mar 15, 2007 | 02:44 PM
big69bob's Avatar
Door Lock Button
I live in Florida where the weather is often nice. But I can't put my arm out the window while driving because the door lock button is right where my elbow would be. The lock does not go all the way down into the door when locked. It is simply a bad design. Do the Acura engineers read this? Please re-design the door lock and move it either forward or down!!!
In the meantime, I tried to unscrew it...but the plastic cap came off and left a metal screw...even worse. Anybody noticed this...or found a solution?
Old Mar 15, 2007 | 03:09 PM
THTL's Avatar
just cut the the lock down a little and screw it back. others have done this. let me search for you.
Old Mar 15, 2007 | 05:14 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
I did this that mod on my accord it works and looks nice and is fairly easy, like said just unscrew the lock buttin cut a little off till it is flush when in lock position and screw it back on it is a good and easy mod!
Old Mar 16, 2007 | 11:29 AM
big69bob's Avatar
cut exactly what
you mean cut the black plastic part that sticks up? Sort of cut it down to like the size of the cover on the valve stem of tires?
Old Mar 16, 2007 | 11:42 AM
leedogg's Avatar
RAR
Others have pulled the door off, unscrewed the plastic lock pin, measured and sawed off some of the base, then screwed it back on.
Old Mar 16, 2007 | 11:53 AM
datmrman's Avatar
The details can be found here: New Mod (Door lock button)
mlody
Dec 4, 2019 02:11 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
