Door Handle lights like the BMW's
i found the DIY but applies to 2G TL. I'm sure there is one for 3Gs as well.
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-door-handle-leds-613711/
But ya...I don't wanna do this on my own either
route a wire from the door lights to the outside, drill a hole in the caps on the end of the door-handles and plug in an LED, your done!
Retired!!! ON TOP!!!
Plus the door light only light up when the door is opened so it defiets the purpose... Of these LEDs on the handle... Then what do you do about the rear doors...
The way mine operate is by the courtesy light circuit... And only the courtesy light circuit... You hit the alarm to unlock the car and the lights turn on etc... There's a thread on how to tap into that circuit...
Good luck ... I've had this mid on my car for years... if I find the time... I will create a DIY on it...
New handles where purchased and the LEDs were fabricated INSIDE the handles (not the cover), since the handle are hallow. If you guys look at your handles, HOW THE HELL WILL YOU GET LIGHT in the circle area from the "key hole cover"???
Yes, the handles light up when the car is unlocked with the keyfob and turn off when the car is started or your courtesy light timer runs out.... but they do NOT turn on when you manually turn on your dome lights...
There was a lot of testing to get the LED in the correct position to fire into the circle area and have an even fill...
One question though how do you connect the LED and feed the wire through the hollow door handles ? (I guess I'll have to try to take the door handles off to figure that out).
DIY process would be great if you have to the time.
Only one LED... after trying different types and countless failures... I found one that works well and it's been a whole year without a hickup... I purchased the prewired superflux from Oznium.com link as follows:
http://www.oznium.com/prewired-superflux
Thank you everyone... we had to custom fabricate the LED inside the handle and run the wires out of the handle such that it doesn't interfere with the handle usage...
That looks sick, that's the way it should be done with the "door handle lights" connected to the courtesy light. Your car is very nicely done. I believe the door handle on the 1 gen TSX is the same and so this mod should work as the door handles are similar.
Holy F, rodney, you're tripping me out. I was looking at these the night before. The way they're designed, all you have to do is Dremel a hole the size of the housing into the handle, then thread the wires which I saw they made a foot long, apply some sealent to the housing, and slide it in. I was thinking the best place to mount it is where the handle pivots. There's less hand traffic there when opening the doors.
But since I have a taste for shooting my way through rush-hour traffic, as well as nice LED lights in my door handles, I'll be careful only to use my machine guns and handle lights when cops aren't watching....
On the serious side- Since the lights aren't on while driving, the police should not care too much. Or notice for that matter.
śïιέит вµт đέαđιý
k what I want to do with mine is have bright White LED's that only come on when I unlock or lock the car...or maybe even when I have the door open..thats about it.
The BMW 7 series has the same exact lights on it (since 2002) and they light up when you unlock the car so you can see the door handles at night. As soon as you turn on the car they shut off. In this case it would legal since you are not imitating an emergency response vehicle. They are purely to see the door-handle at night, and as well to see the floor so you don't step in something you don't want to.
Alright... let me market my FOR SALE Thread of my Blue LED Handles as shown above...
Here is a link in accordance to Black Market General Rule #11...
https://acurazine.com/forums/car-parts-sale-361/blue-led-door-handles-custom-wdp-3rd-gen-tl-lqqk-737006/
Happy Shopping...
Happy Shopping...
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
ahsm
09-09-2015 08:35 AM
