Dome Light Question
Dome Light Question
Hey guys,
I've tried searching for this but couldn't find the answer. I am curious if the dome light automatically turns off after some period of time passes when you lock the car. So more specifically, that switch near the moonroof opener has 3 positions, off, on when the doors open, and on. So if I leave it on and close the door and lock the car, it seems to stay on. Does it turn off automatically after some time?
Thanks.
Thanks.
It gets dimmer and turns off when it's set to middle position. So it turns on when the doors open, then when you close the doors, it dims and turns off. However, if it is in the on position, it stays on when the doors close and the car is locked.
The Interior Light Dimming Time that you are talking about only applies when the switch is in the Door Activated or middle position. When it is in the I or ON position, the light stays on even after you close the doors and lock the car with the remote. So apparently this means that if you forget it like that, you will drain your battery. Unless there is some cutoff time that the manual does not mention.
Registered TL Lover
yes you will drain your battery it happen to me when i took a trip back to the states for about two weeks. i almost freaked out becuase i didnt know how to open the trunk without power to get to my car jump start kit and since it was a weekend there wasnt hardly anyone on base where the car was parked. simple problem yes but when your comming off about 10 hrs of flying and another 3 of airport hassles the simplest thing can get on your nerves
If it stays on even after the ignition is cut, the system design is flawed. It should cutoff automatically after, say, 20 minutes, to prevent battery drain. Many cars have this feature. My other car, a Maxima, does that. We have to read the owner's manual carefully to find the true answer, instead of guessing what might happen.
Originally Posted by borgit
How did you get the trunk open with the battery dead? As I recall, our TL's dont have the option to open the trunk with the actual key.
Pull down the center portion, open the plastic cover, and reach in at the top and you will feel the handle. Pull on it and the trunk will open.
mada51589
05-03-2022 08:54 PM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
