Do you keep a hammer in your trunk?
No, not for nefarious reasons
Yesterday evening I had a flat and after removing the bolts in the cold 25 degree weather without gloves (it was supposed to be just a quick trip to the grocery store), the wheel would not come off. So I called AllState road side assistance. Spent over 30 minutes on the phone with them but they could not find anyone to come out, neither under contract nor for me paying directly. The lady said she called 16 towing places around me but they wouldn't come out.
I tried tapping the wheel with my foot, the wheel wrench, and even tried bumping it with the spare wheel to no avail. Thankfully, there was a hardware store in pretty short walking distance where I purchased a hefty hammer. A couple of thumps on the back side of the wheel and it popped loose.
So does anyone have a good scientific explanation for why the wheel to gets stuck to the hub? This one had been on for less than six months - when I last rotated tires.
Originally Posted by pohljm
It would have been alot easier for you to just let the jack down to bear a little weight on the wheel with the lugs off or loosened and that would have popped it loose for ya
lower the car a little bit and kick the tire at the bottom and then the top. Repeat until it comes loose, then raise the car up a little. Or you can lower the jack so the weight of the car is back on the wheel, but that may not do to much good as the hub will still be on the rims and will not get that loose.
i guess you've never owned a BMW..... try removing one of THOSE wheels without a sledgehammer or baseball bat... the TL? i've never, ever had a problem, and i've removed my wheels over 15 times.
Seems the wheel was overtightened if you ask me. Keep a lead pipe in the trunk that will slide over the end of the wrench in the tool kit, gives extra leverage and is useful for nefarious reasons if necessary.
i keep a lead pipe, for other reasons, but it can also come helpful in your situation
also got a baseball bat and a machete, in case the Yankees want me to play for them or if i ever get stuck in a jungle
if there was any lube/oil around the hub, it might have frozen a little witch makes it expand and that would cause the wheel to not come off?? it would have made the fit in between the tire and the hub really small.
I think the reason why the wheel was hard to come off is because the rotor surface (where the wheel is mounted) was rusty.
When I took my car to have them rotated (Good Year) last month, the guy had a hard time taking on of my wheels off. The manager came over, and told me something about rust buildup. So he had his tech sand the excess rust off, so next time the wheels will be easier to coming off loose.
Originally Posted by SouthernBoy
For the other reasons, carry a gun.. it works better.
If you guys think this is bad, imagine how much fun those 18 wheeler drivers go thru during the winter...lol...try to use a little hammer on that...
the cause is corrosing due to two dissimilar metals, the aluminum on the rim and the steel from the rotor react and corrode causing it to stick like it did. I drove a tow truck for many years and usually when I encountered this problem giving the rim a good whack with the spare would knock it loose, if it was really stuck then I would resort to hitting it from the back like you did
Originally Posted by TeknoKing
Shooting the tire? LOL (j/k)
Originally Posted by KaMLuNg
nj is strict
Next time you have the wheels off use a wire wheel etc to clean the hub area then a thin layer of wheel bearing grease or the like will help a lot.. Notice I said thin .. don't gob it on. Anti Sieze also works but don't use it on the bolts.
yes, this is a bummer. kick the wheel while the car is on the jack and it falls over, not fun.
seen this with my preveous Supras. it's a problem between aluminum and steed (dis-similar metals).
i've been told to coat the face of the hub (that meets the rim) with anti-seize, supposed to fix that.
don't know if it works, but i did come close to kicking the car off the jacks a few times.
chris
chris
lol for some reason my trunk is the equivalent of a home depot, i have 2 hammers , 225 piece craftsman ratchet set, a whole bunch of skrew drivers, nails skrews, a power drill, attachments for the power drill, and a skill saw
Jul 16, 2017 07:33 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
