do you do it outside or inside?
Old Apr 28, 2007 | 08:05 AM
kris10950's Avatar
i just order pc7424 and waz n sealen, question is i don't have a garage, so can i do it out door. The glasse sealar said let it sit for 6-8 hrs. thanks.
Old Apr 28, 2007 | 08:36 AM
trancemission's Avatar
Regions Leader
Im sorry but I honestly dont understand what you just asked.
Old Apr 28, 2007 | 10:33 AM
Jesstzn's Avatar
Me either and I have a PC7424.
Old Apr 28, 2007 | 10:41 AM
kris10950's Avatar
sorry, after i wash and clay my car, do i need to bring it in the garage for waxing using the PC-7424. also the" Klasse" product said to wait 6-8 hrs. for most affectiveness.
Old Apr 28, 2007 | 01:03 PM
Jesstzn's Avatar
The PC is used to polish out any swirling etc not to apply / remove waxes/sealants.
Here is some Klasse hints
Klasse SG Wipe on, Wipe off, Official Application Instructions
Considering I've been getting PM's asking me to outline my official SG application/removal technique, I thought I would go ahead and start a thread that covers exactly how I perform wipe on, wipe off.
My technique is pretty simple.
In order to apply SG using wipe on, wipe off, you should do the following:
1. Take a new yellow foam applicator and spray it with water.
Squeeze the applicator as much as you can so that most of the water is gone. All you should have is a slightly damp applicator. This will make the SG more pliable.
2. Apply a couple of drops of SG to your applicator and apply it to a section of your car (1/3 of the hood, half of the roof, etc) in a front to back motion. Once you have covered the whole section with SG, immediately wipe off the residue with a MF towel that has been lightly misted with distilled water. Wipe off in front to back motion.
3. Repeat step 2 for every section until the whole car is done.
Notes:
- As mentioned before, wipe the SG off immediately, no dry time is necessary.
- The SG should wipe off very easily leaving behind a slick, smooth, and glossy finish.
- You should use no more than 1oz. of SG per coat on a regular size car (BMW 3 Series, Mercedes-Benz C-Class)
- Only perform step 1 one time, before applying SG to the first panel. You do NOT need to spritz your applicator with water before applying SG to each section. Once you apply SG to a couple of sections the applicator will be wet enough with SG, negating the need for more water.
-Do not use any QD to aid in removal of SG. This will / may cause the klasse SG to develop an oily haze/film down the road. I've also experienced this.
-Wait AT LEAST 24 hours before applying another coat of SG. SG needs time to cure and bond to your paint surface. I would personally wait a week. If you've driven the car ANYWHERE, then wash it before applying the next layer, or else you will just re-swirl your car.
-Put on three coats of SG, and you will be good to go.
-If you desire more warmth and depth in your paint, then apply a carnuba wax a week after you’ve applied the third layer of SG. Make sure you wash before you wax. You may experience some streaking or ghosting of the wax. I did, but it wasn’t enough to bother me. This is because SG and carnuba (any carnuba) don’t entirely get along. Consider yourself warned.
That's it!
Old Apr 28, 2007 | 09:59 PM
gauravp123's Avatar
RBP > WDP, NBP, SSM etc
wherever the girl wants me to do it...couch, bedroom, kitchen, floor etc
ROWDY621
Sep 30, 2015 03:20 PM
hashbrown
Sep 29, 2015 12:13 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
