DIY Video: Uninstalling OEM Intake & Installing Cold Air Intake 3G Garage #B-001
Old 04-19-2010, 10:14 AM
  #121
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
Originally Posted by kidrocking79
Anyone know if putting in an aftermarket CAI will void warranty? I don't want to go to the dealer one day to get something worked on that's still considered under warranty and have them say that I have an aftermarket CAI and I just voided the warranty.
You have to look up "Magnusson-Moss Act" for details, but the short answer is Yes and No.
No, it won't void warranty UNLESS the failure is directly attributable to the modification. For example, a CAI has no effect on, say, ABS modulator failure, so the warranty for the ABS part should be intact. This is the crux of the Magnusson-Moss Act.
Yes, in the sense that the dealer MAY either outright lie to you or find some cockamamie connection between your CAI and whatever fails to deny your warranty claim. Depends on the dealer.
Old 05-02-2010, 09:51 AM
  #122
kidrocking79's Avatar
Excellent.. just did my AEM CAI. My vibration mount was in a different spot though. it was inside the engine bay as opposed to where the grounds are. Aside from that everything else was the same.. oh.. and don't forget to unclip your fogs before you go yanking on your bumper too much... lol
Old 05-02-2010, 09:57 PM
  #123
MRTaylor's Avatar
Would you even have to take you bumper off if the aem mount is in the engine bay?
Old 05-02-2010, 10:33 PM
  #124
well... it helps to make it easier to get it down there... Don't think it's absolutely necessary, but I'm sure it's just easier. Plus taking the bumper off is literally 15 mins. It's really up to you. I took it off thinking I was going to have to do that.
Old 05-11-2011, 01:07 AM
  #125
mrtrojanap7's Avatar
Thank you very much for the video, it helped tremendously!
Old 06-08-2011, 12:04 AM
  #126
Project X's Avatar
Saw the DIY install video. How do you take off the resonator box without taking out the front bumper? Will taking out the driver front wheel be sufficient?
Old 06-08-2011, 08:53 AM
  #127
dwb993's Avatar
Just take off the bumper. It only takes 20 minutes (tops) and gives you all the clearance you need to do whatever you want to do. The OEM intake tract can be a pain in the ass to get out---even moreso without removing the bumper.
Old 02-02-2012, 05:17 PM
  #128
JDECON's Avatar
CEL Light
I know old thread. Just installed aem v2 and engine light came on. Is this normal or did I mess up the tubing for the coolant? someone please chime in. tks jp
Old 02-02-2012, 06:45 PM
  #129
JDECON's Avatar
forgot to put pic. Pic shows coolant going to somewhere to the engine. Hopefully this is right.
Attached Thumbnails DIY Video: Uninstalling OEM Intake & Installing Cold Air Intake 3G Garage #B-001-photovcg.jpg
Old 02-02-2012, 09:08 PM
  #130
AZ Community Team
Bearcat94's Avatar
It's not uncommon to get a CEL after install. The way to avoid it is to remove the NEG battery terminal before starting the install.
It should go away after something like 20 miles or 30 minutes of driving - long enough to make you wonder, but not too long.
Can't really tell what's going on in your picture. Which line are you concerned about exactly? Can you show a slightly wider view along with the close in view?
Old 02-02-2012, 09:40 PM
  #131
JDECON's Avatar
Bearcat,
Tks for replying. I just want to make sure that the coolant goes to these two lines. Im glad that other people have gotten CEL's before. I didn't unplug my battery until halfway through when I realized that the aem v2 would not fit through the hole unless the removal of the battery.
Attached Thumbnails DIY Video: Uninstalling OEM Intake & Installing Cold Air Intake 3G Garage #B-001-photoaafda.jpg   DIY Video: Uninstalling OEM Intake & Installing Cold Air Intake 3G Garage #B-001-photodfasdf.jpg
Old 02-02-2012, 10:17 PM
  #132
AZ Community Team
Bearcat94's Avatar
Looks like the Throttle Body coolant line?
You're in SoCal, right? If so, you should do this: Throttle Body Coolant Bypass (link).
Old 02-02-2012, 11:02 PM
  #133
JDECON's Avatar
Bearcat,
Yeah i live in socal but i probably wont do the bypass. Do you know if i have the throttle body coolant attached to the right areas
Old 02-02-2012, 11:22 PM
  #134
AZ Community Team
Bearcat94's Avatar
Originally Posted by JDECON
Bearcat,
I can't tell from the pics. Look at the pics in the linked thread for the inlet and outlet ports on the TB. If that's where you're connected, you should be good.
Old 02-02-2012, 11:25 PM
  #135
JDECON's Avatar
I looked at all the threads and saw where the tb bypass was unplugged and where it was rerouted too. I have my tb going to the rerouted so i just want to make sure i didnt put coolant somewhere its not suppose to be.
Old 12-06-2012, 07:07 PM
  #136
Project 04TL's Avatar
talking myself into taking the bumper off was the hardest part .. went on without a flaw .. thanks for the video
Old 11-10-2013, 08:04 PM
  #137
5th Gear
R_Mariota619's Avatar
thanks!!! great DIY vid!
Old 07-05-2014, 10:03 PM
  #138
kingbharj's Avatar
Is this for Full Cold Air Intakes only? Would a Takeda SRI be the same process? or would it even fit on an 08 TL?
Old 08-16-2018, 08:45 AM
  #139
3rd Gear
Casper'sTL-S's Avatar
These video links aren't working.
Old 08-16-2018, 12:33 PM
  #140
wusty23jd's Avatar
Only the first link no longer works. However, a quick YouTube search yields the needed videos.
Old 08-16-2018, 12:37 PM
  #141
Received 8,709 Likes on 6,716 Posts
Fixed links, thank you for bringing it to our attention.
space_boy
ILX
51
08-15-2017 12:06 PM
hues10
1G RDX (2007-2012)
09-07-2016 03:47 PM
drone619
01-26-2016 07:09 PM
theinsvnity
09-10-2015 10:22 PM
dlknight
09-03-2015 07:54 PM
Quick Reply: DIY Video: Uninstalling OEM Intake & Installing Cold Air Intake 3G Garage #B-001
