DIY Spark plugs
DIY Spark plugs
Hi,
I just got new NGK spark plugs b/c of some hesitated startings over the last few days. But when I opened the hood, I didn't see the plugs. I did notice 4 plugs (or something that looks like them) that may be spark plugs but the TL is suppose to have 2 more. I am probably loking in the wrong place. Any images/pics will be helpful.
THanks.
THanks.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
the link above shows the coils which have to be removed inorder to access the spark plugs. the coils are located both on the front valve cover and rear valve cover. you will see the oil cap in the picture to give youi an idea where they are. just remove ht screws for the coils and the wire plugs and pull ciol straight out. then use and extension and spark plug puller. hope this helps!
Originally Posted by dips009
Inthe 04,3 of the plugs are right in front, but can't seem to find the next 3. There is nothing under the metal plate stamped with vtec or acura tl it says.
Ummm...perhaps you should think twice about changing these yourself? Have you gapped them correctly? Make sure to use anti-seize on the threads, and DONT cross thread one, or you will be in for a bunch of trouble.
Honestly, I wouldn't wait 100K for a plug change. I don't know the specific makeup for the TL's plugs, but I know in many of the domestics that claim a 100K deal use platinums. The Grand Am I had burned those platinums pretty well by 40K. Granted, they were still more than useable, but the NGK's I replaced them with were quite nice, especially at WOT.
I've been lazy, but I've got a set of Denso iridiums for my 04 TL ready to go whenever I get off my ass to do it. :P
edit:
Chester's right though... do NOT mess up the threading. If you've never done a set before, be damn careful. The anti-sieze is great, especially the next time around, too, btw.
edit:
WDP Director of R & D
Very true!
When changing plugs on aluminum heads, always thread the plugs by hand then use your ratchet etc.. Utilizing a torque wrench is also a great idea... I myself tend to over-tighten otherwise..
Ive never looked but are the TL plugs tapered or do they use a crush washer etc.?
This is one of the things I like about what GM does with their transverse mounted engines... On the dogbone enginemount on the front of the engine, you can remove the bolt, tilt the engine forward about 10 degrees, and put the bolt back in to hold the engine. That way you have more room to reach the back 3 plugs.
And yes, DO NOT cross thread or overtighten the plugs. And a worde of advice.... When you remove the plugs, use a socket plug that has the little thimble looking thing at the end that grabs the socket by the tip. DO NOT get the kind that uses a little rubber tube to grasp the socket. I helped a friend with one of those where the tube thingy came off, and got stuck on his spark plug while still in the head. It took about 3 hours to fiddle with the thing and remove the one spark plug, because the tube thing wiggled its way ontop of the hex nut thing, so that the socket could no longer turn the spark plug, which was still fully tightened.
Thanks for all the good advice. I chnaged the front 3 pretty easily. I'll need alot more time to get the back 3 plugs.
The car doesnot start on the first try so I am chnaging the plugs hopeing it will fix it. I have a CAI so I am kinda hesitant taking it to the dealer b/c of warranty issues. But most of all, I am hopiung its a bad tank of gas.. Thanks.
It's nothing but Chevron for my TL now... Unless I'm running on fumes, and need to go to the Shell station near my house....
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
