DIY: Replacing Cabin Air Filter 3G Garage DIY F-130
#241
NBP is a pain...
[quote=gotkilled;11368638]
Hey Guys, a couple quick additions here:
1) Fram Fresh Breeze Filter
I've got a 2006 TL with 58k on it, and am replacing the filter for the 2nd time. The first time, I just drove to Advance Auto and picked up the regular paper filter for like $28+. This time I really wanted to get a better filter with the charcoal / carbon filtration. I agonized over whether to get the WIX, bosch, etc, etc, and saw some conflicting information about part numbers. Then, I found the Fram Fresh Breeze filter, which I think is somewhat new because there aren't too many posts here about it. (I'm not normally a Fram user, but the Fresh Breeze is very good)
I can 100% say the correct part number for my 06 TL is: CF10134 This fit perfectly, and you can really see the charcoal in the filter media, and there is supposed to be some baking soda as well for odor elimination.
I ordered it from Amazon with free shipping, and the price was around $15. After much research, I think this is the best way to go.
+1 on the Fram Fresh breeze air filter.
#242
quick question, when you guys installed the ATP HA-5 charcoal filter, was there arrows showing which side to replace back? cause mine didint have any arrows watsoever and just replace the new filter back with the darker side facing up and the lines going horizontal...the charcoal was 2 colored right? one side was lighter white and the other was darker grayish? or was i blind during the process?
#244
wow this was by far the easiest thing ive ever done on my car. ive had problems installing intake, and doing my interior led's which both gave me a shit load of trouble each. this is seriously so easy!
#245
That happened to my 97 CL. Messed up the back seat pretty good and the seat belt as well. do you know if this happens on 2005 TLs?
#248
Just changed mine. got a WIX cabin air filter at ABC auto for $9.95 (after my companies cash ticket discount haha). Thanks all for making this thread, saved me time for sure. And yea, I was nervous pulling the glove box housing, it took more force than I thought it would.
my $0.02: there was next to no slack in the trunk switch wires, so disconnect it ASAP to avoid damaging the wiring.
#249
I changed mine today, only took me like 5 minutes here is a picture of the old filter. sorry for the quality I took it with my phone. I paid $28 for the OEM filter !!
#250
Feenin on some 20's
Just an FYI, the cabin air filters have a $5 Mail-In-Rebate if you purchase one charcoal filter from ATP!!!
http://www.rockauto.com/lang/en/promo.html
#252
Fear and Loathing in my
Replaced my filter today. I bought my car 1 year and 5 days ago with 43K on it. I have about 51K on it now, and decided to replace my filter. I wasn't sure if Acura did it or not, so I waited some time. These are the horrific pictures of the old filter that I took out. It seems to me that it has not been replace in YEARS!
This is what it looked like in between each filter.
I recommend ANYONE to do this if they have not in at least one year, or is they have recently bought their car.
#255
When you can, for these type of parts, go to Honda first, not Acura.
#257
I just changed out mine, and it looked somewhat like Timb227's but not QUITE so bad I'm thinking its never been changed out for the 60k miles the car has. Just knowing I'm nothing breathing in pollen spores anymore is good to know
#258
Yeah, none of the procedures seemed to answer the question for us early 2004 TL owners. It's too bad there aren't any screws to be found. Thankfully, the pics on pg 4 with the cut out of the glove box helped me "guess-timate" where to trace and cut out an access for the cabin filter. Thanks
#259
Its really easy to get off, especially for us 04s since there is only 2 screws to remove to take the box out of the compartment. The hard part is getting everything back in
#261
Thanks OP and others for the write-up. Saved me a nice chunk of change in not having to pay for the 2 service (replaced air filter with K&N at same time as cabin filter). I went with the Fram Fresh Breeze and here's my old filter for the "contest". Thanks again!
#262
Has anyone successfully replaced the filter without removing the whole right side of the dash? I was able to get the door down all the way but didnt want to venture down too far from there.
#263
Veeeee Tec
I bought my 04 with 57k and now have 109k. I just replaced it today and wowwow. I've never seen anything like it. Black chunks throughout the whole filter/ Leaves and other debris. The filter didn't say Honda on it. It said Microton.... So i beleive it was replaced but it's atleast 60k or so old.
Turned on the AC on full blast and let it run.. So much fresher.
#266
TEAM_SONIC
What is the correct way to place the ATP filter into the tray. I know that the OEM filter has the air flow arrow showing the correct way to place the filter. But with the ATP filter, one side is darker than the other. I want to know which side face down. Thanks in advance.
#267
#269
Changing cabin air filter on '06 TL
Just thought I'd add my $.02 on the process...
I just changed the cabin air filter on my '06 TL. I used a Purolator C35519 I got at Advance Auto Parts for less than $15.
I dropped the glove box on its hinge by pushing in the molded fins (one on each side on the outside of the glove box liner). (There are pictures elsewhere in the thread.)
I removed the glove box liner by removing the two screws near the hinge, one on each side.
I removed the glove box housing by removing the two screws with washers at the bottom (pictures elsewhere in the thread). I also had the two pushpin fasteners at the top of the housing (push in the little round disc in the center to pop, then lift out the whole fastener with a flat edge).
Then I pulled the housing straight out, starting with the right side. By "straight out", I mean on a plane level with the garage floor. This popped out both clips at the top.
There was some gaffers tape holding a wiring harness on the back right-side of the housing. I untaped it and had enough room to swing the housing up so I could pull out the filter without disconnecting either of the wiring harnesses going into the housing.
My filter was filthy. 75k miles on the car and I don't remember the filter ever being changed. The Purolator filter had air flow marks on one side so orientation was easy.
Then put everything back together in reverse order. I did push in the housing on the right side first so that clip clipped first.
The only gotcha I had was putting back in the pushpin clips at the top of the housing. The trick is to push the claws back in towards the outer ring until they lock in place in a closed position. Then when you then put them back in the holes, they will spring open and catch.
Total time for the process? Probably 20 minutes, but five minutes of that was figuring out how the pushpin clips worked.
I haven't driven it since changing the filter so I don't know about any new rattles. (My glovebox has had the usual rattle for a while now.)
This thread made this whole task very easy and straight-forward. Thank you to everyone who contributed.
Next up? Changing the engine air filter.
#270
Make it so
As for you guys talking about dirty filters, I think I win. I changed mine in January/February and I don't think the previous owner EVER changed it. Figures, they were old people.
I win.
#272
Head a da Family
I just installed my HA-5 filter this morning with another one. There are no arrows, but seeing as the air flow is DOWN (into the floor vent), I just put the darker side facing up. At the end of the day I don't think it really matters, either way the air will flow through the filter and hit all of the filter media.
I win.
I win.
#273
Make it so
Sorry, I should've clarified that. But yes, that was the old filter. The previous owner was tremendously meticulous when it came to maintenance, or so it seemed.
#274
I just replaced this filter on my '04. It had the screws that had to be removed like the newer models, but did have the push-pins at the top along with hidden clips. It didn't have the plastic clips inside the glove box either. I'm guessing mine is a late-'04?
My TL now has 97k miles on it and from the looks of the filter it, it looked OEM and dirty as hell. I replaced it with a charcoal activated one that I bought from walmart.
The whole process took maybe 10 mins... even with me spending the time to spray cleaner all over to make sure everything was clean before installing the new filter.
Very easy to replace filter!
#275
2011 CR-Z EX 6spd Navi
Thanks again for the write up
#276
I changed mine for the first time and it was pretty easy. It's amazing how dirty the filter gets! I used this Youtube video to help out:
http://www.youtube.com/watch?v=FQsDxqxyeqM
#278
RAR
