DIY: Replacing Cabin Air Filter 3G Garage DIY F-130
#162
Thank for the super diy, have any one here have use the FRAM Fresh Breeze cabin air filter ?
#163
I just changed my filter.
Here are pics. Thanks for the DIY. Don't be fooled by the first pic at how white it is. The flash made it seem much cleaner than it was.
I took a second pic to show everyone how much shit can collect. 60 000km on that filter.
#164
Thanks for the great DIY whoever started this thread. I just replaced mines today and was thinking about cutting an opening in the back panel for easier access to the air filter for the next time I have to replace it, but since everything was so easy to remove in my 04 TL, I decided to not modify anything. The change was a piece of cake, I can't believe they charge hundreds of dollars for this!
#165
Those white things actually are Styrofoam pebbles. I have no idea where they came from.
My vents blow much stronger air now. I was actually wondered why my vents blew so weak before but now I know.
#166
The filter collects gunk from the outside air. I just check mine, and after 2-1/2 years, it is clean as new (it has never been replaced). The reason is because I never run without the Ricirculation turned on. So, I never pull in outside air (and gunk floating in the outside air) to foul the filter. Not meaning that is the reason I always have recirculation turned on.... that is because I don't want the humid Houston air pulled into my car.
#167
Team Nighthawk Mambo King
Great thread, I read it about 10k miles ago and had been meaning to do it, today I decided that at 36K was long enough and did it in about 15 minutes. One thing I will mention is that Autozone wanted $35 and Advance Auto had it for $13... ..why such a difference in price..??....maybe the Autozone filter came with the rubber case...not sure...but almost 3X the cost...go figure...
#168
Wow, filthy is the word of the day. Thanks to all who contributed to this thread. You guys just saved me $120.00. You guys are the BBEEEESSSSSTTTTT ARRRRROOOUUUNNNDD. It only took about 10 minutes. Time to get some beer.
#172
So is there any special technique for removing the glove box assembly on the '04 TL? I really don't feel like cutting it and I don't want to break the clips. Pretty lame design if you ask me but at least they went with the push-pins in '05 I guess...
#174
#175
Originally Posted by A SiQ TL
Ummmmm....... its in the very first post
#176
Registered Member
And yes, it certain is a pretty lame design.
#177
Registered Member
Ah I totally read that wrong. I thought the '05 TL's had the push clips and the '04 TL's did not. Nevermind. So the '04 TL's should be fairly easy to remove the glove box assembly.
#178
i just did this on saturday and it was a pain in the a$$, but not as bad as changing the engine air filter.
It's a bit un-nerving just pulling off the plastic portion and putting it back on was just a pain. i think i lost one of the plastic pins inside. oh well, it got done and the filters were dirty, so i saved a couple of bucks.
#180
Registered Member
#181
Cabin Air Filter on '06 TL
I read this thread a couple of days ago and noticed most of the cars were '04 or '05. I figured it would be about the same on my '06 and picked up a filter while I was at the dealer getting the Power Steering recall taken care of.
I was actually pretty surprised at how easy it was, on the '06 the air filter is directly behind the glove box. Taking out the glove box was a snap and I was able to remove a couple of vinyl trim pieces pretty easily once I figured out how hard to pull.
My car has 32,000 miles and I know it was overdue but I was shocked at how filthy the old filter was, I'll defiantly be changing it again in fewer miles this time.
#182
I just changed mine (3 years old) and was shocked by the amount of crap that was in the filter! Leaves, etc. Pretty much just like what others found.
Total turnaround was like 15 minutes for me. Thanks to whoever posted the pics of the '05--it helped out a lot!
#183
FTW
I just did mine, with a custom dremel hole cut
Took me 1.5hrs to get the install done, clean air ftw!
This was after 27k miles, i'd say it was 70% dirty, and the outter edges were still white.
#185
Received 2,599 Likes
Just did the change in about 8 minutes on an 06 (26,000mi/first change) which is a little different then the original pictures.
I did not remove the glove box, just lowered it onto my legs to support it. I also pulled the under tray before trying to pull out the main glove box housing. This tray has 3 of the clips in it pointing straight up so by removing it you have an easier time getting the housing out.
On reassembly the only thing I found you need to watch is the clip on the far right panel near the door hinge. Make sure it engages before you seat the other clips.
The change has cut down the fan noise & improved air flow.
#186
I have 19,000 miles over 2 years and my filter was VERY dirty- similar to the pictures from xo1rider above. Thanks to all the help on this thread- it certainly made the job easier!
A few of the clips are mangled and some were never installed from the factory. I cut the hole in the inner housing so the next replacement will be a snap. I also took this opportunity to replace the glove box light with an LED bulb but oops got the wrong bulb from superbrightleds so that mod will be deferred. Since I cut the hole and am missing clips, I'll wait until Monday to reinstall the glove box so I can buy some clips and do the job right. The downside is the trunk open button in the cabin doesn't work without the switch connection, but otherwise all is well.
I also wound up replacing the engine air filter (thinking it would be equally dirty) and that job is MUCH easier- it's just like my Pilot with the hardest part being unclipping the power line plastic clips.
#188
I fixed the glitch
My first post!
Everyone, thank you for the instructions! It took me all of 10 minutes to change. I used the ATP filter. Mine was clogged but airflow was not bad.
#189
WDP Director of R & D
I'm planning to change my filter and was wondering if anyone sprayed a product to eliminate odors directly to where the filter is. I'm thinking of getting a can of "BG Frigi-Fresh" and spray it with the filter out and the A/C running.
Do you guys think it will be effective?
I'm not sure why some cars get stinky and others don't. The TL is definitely one that does.
#191
#193
信是寶
#195
My TL can do this, too!
get something skinny like a toothpick and push/poke the little circle in the middle using one hand, while in the other gently use a flathead screwdriver to wedge the whole thing out.
#197
2011 BMW 335i
1 Post
Just did this today! Went to Kragen Auto Parts and bought the Bosch cabin air filter, which cost me $19.99 + tax. AutoZone wanted $29.99 Anyway this task was a pain in the a-hole! I actually broke the clips cause I think I pulled a little too hard. Oh well I hope the rattles won't be too bad. Anyone know how much it is to replace the panel behind the glove box. This is the one I broke.
#198
So this is a great DIY. Just did my 07' TL and have a few things to add that I didn't see so far.
This first picture is of what the clip looks like. It helps me pull it off when I know what I'm pulling against.
Next picture is of where all the clips are at. There is one on the bottom right as well just couldn't get it in the picture. The clips on the side are towards the center of the car. I started on the side closest to the door and worked over.
This is a picture of the harness for both the switch and light. Push down on the top and pull off. They will come right off.
Last set is of the 2 clips for removing the panel. This is what the clip looks like when you push in the middle and bring it out.
Push in the 2 legs to where the center is pushing out the front. Then once you put the clip in, just push on the center until it's flush. When it's flush the clip is secure.
Hope this helps and sorry for the big pictures, it's what they got sized to.
#199
2011 BMW 335i
1 Post
Guys be careful. As I said in a previous post, I broke these clips and just to let you all know the rattle I have now coming from the glove box area is really bad. Good thing I listen to music all the time or I would go crazy. I will fix it next chance I get.
#200
I went on the site and see a few filters available for an 2005 TL?? Just wanted to confirm "ATP Part # HA5 {Vent Filter}" is what I want? This is the charcoal activated one? Planning to work on my within the week and want to order ASAP. Thanks.
