DIY: Ebay Accord Foglight Wiring
#122
I have a ACURA Tl 2005 Base but i dun have the holes for the fog lights nor do i know what to do. My basic question here is....do i have to buy a new bumper before i can do this mod? from a newer car >07s i guess or what? how does it work?
thx for the help
thx for the help
#124
Check out the 3G garage...and you can check out some threads I have from a year ago...look up my name, statistics and look up threads started by me. I had some decent info on it back them.
No, no new bumper...just a big set and a dremel to cut into your existing bumper and bottom grill. When all is said and done there's a HUGE margin for error and it will look professional. Plus, if you screw up you can always rebuy the bottom pieces and cover your mistakes up.
Order the 2003-2007 (?) 4 door accord foglights. Those are the ones that best match the opening in our bumper.
#125
Hey guys I have some newb question that I had in my mind for a while, and I have read a lot of this thread before I am going to post this. I am planning to attempt this fog light project and I just want to ask about the wiring before I start cutting away. So I am planning on picking this one up ( http://cgi.ebay.com/ebaymotors/2003-...Q5fAccessories ). I am going to try to connect it so when the low beam is on, the fog lights would also come on. I want to do the connections like how one of a member wired it.
-The red/white/yellow wires they are together I cut the white wire down and tapped it off. Wired the red/yellow to the + on the battery using the main battery fuse of the car as my fuse.
- The brown connector with the green/blue wire, I cut the brown connector off and cut down the blue wire and tapped it up. Then I wired the green wire to the low beam headlights. I did this by connecting it to the fuse in the fuse block under the hood.
I am trying to wire it my way to see if its okay, want some advice from members to see if the wiring is correct before I do something stupid.
-tap off the white wire, and wire the red/yellow straight to the battery.
-tap off the blue wire, and connect the green wire to the headlights positive wire.
What do you guys think about that way, is it okay or do I need any fuses in between anywhere. They way the member describing about connecting to the fuse block under the hood confused me so I don’t know where that is so don’t think I want to attempt that way if I don’t know it that well (unless someone can explain it to me or have pictures of it would be great). Any suggestions or advice would be great, thanks.
#126
I'm not going to refer specificially to your wire choices because I have OEM so the color might be different.
In ENGINE BAY:
I have 1 relay...2 (to 1) wires go to ground 2 (to 1) goes to each actual light. 1 to power (with an inline fuse at least 20AMP) and 1 thru the firewall to the switch.
AT SWITCH:
1 wire to ground
1 wire thru the firewall to the relay
1 to get signal for when to turn on. (originally I wired this to parking light, but I didn't like to have to remember to turn it off every time because of the on/off of parking lights when locking/unlocking car with HID's so I rewired BACK thru firewall to the lowbeam fuse in the fuse box in the engine bay...I coudlnt' find the lowbeam wire anywhere under the dash).
J.
In ENGINE BAY:
AT SWITCH:
1 wire to ground
J.
#128
ok i just recieved my lights and this is my harness for the fog light im just trying to figure that one wire. You guys have different harnesses and i was reading about tapping into the parking lights. But im not sure if this is the wire that you guys are talking about
1) The harness you have labelled with the white balloon looks like the interior switch harness. The green plug goes to the switch, black to ground, red with the green tinted connector goes thru the firewall to attach to the underhood harness and the white wire connects to the parking light signal wire in the OEM harness under the dash. You should be able to find a pic of that harness farther back in this thread. I would have expected another wire for illuminating the switch, but don't see one on your harness.
2) The other harness is the underhood harness. The red wire marked "12 volt" connects to the battery at the fusebox---use the terminal closest to the rear of the car. Black is ground. Red with the tinted green connector goes to the similar wire on the interior harness (thru the firewall). The only connector I can't account for is the one next to the relay---I don't know what that one is for.
May be someone else has seen this harness before?
EDIT: Duh---I think it's the fuse holder! 20A
#129
#130
05 SSM
These cables look a bit different from the ones I've seen, but I'm going to take a stab at it anyway:
so basicly i should splice the white wire and tap it into the parking light. so is the white wire a ground or positve?
#131
Its a positive, but its only a signal wire to the relay. When the relay sees power on it, it closes to send power down the underhood harness to your lights directly from the battery.
#132
i have a question, im installing the fogs but not putting a switch in, i just got a fuse connector to plug into the fuse box under the hood, but i dont know which fuse to use, its very hard to read the decription under the lid, can someone just tell me what number fuse to use and how many amps it is? theres all of these weird names like L-H LO, L-L LH , H-L ON, that i have no clue what it means.
#134
I have marked the connection points for the main power to the relay (red) and the parking light fuse #4 (yellow) for the signal lead on the relay.
Use an Add-A-Fuse on fuse #4 (http://www.google.com/products?q=add...ed=0CCMQzAMwAg) and make sure the fuse holder on the power line is rated for 20A (green).
Note these instructions are for wiring the fogs to come on with the parking lights with no switch on the interior. If you want a switch, run the wire connecting to fuse #4 to the interior switch and use the Add-A-Fuse in fuse #32 ACC in the fusebox in the drivers footwell for the switch power. This allows the fogs to be turned on when A) the switch is in the ON position and B) the ignition is in the ON position.
#135
connecting to fuse #4 will turn my fogs on when i have my parking lights on and the running lights? or parking only? i just want it to turn on when i have my running lights on, so 2 counter clockwise clicks on the switch in the car
#136
If by "running lights" you mean headlights, use either #1 or #6. Understand that those are 15A circuits and some of the Add-A-Fuse units are only rated to 10A. The link above has a Marine grade unit rated for 15A. The fogs will come on with the headlights--two clicks on the stalk.
#137
Looks good Gerzand...mine look similar but your rear is cleaner than mine and looks like it points more downward. Like I said before...this proves my point...there's no REAL way to get this right or wrong...just do it slowly.
#138
Here ya go.
#141
thanks it is very helpful. Don't really know nothing about the fuse so hope I dont mess anything up. I wanted to ask about the link you put in does the blue part connect to the igniter power wire for the fogs so it lights up when you have your head light on correct. sorry for the newb question. Just want everything to work so I dont blow anything if i do it wrong. Thanks for the help
http://www.the12volt.com/relays/relays.asp
Note that we are using an SPDT relay.
Basically, the relay is an on/off switch for the main power flow. It is triggered when you turn another device on or off.
So, in this case (fogs installed, no internal switch), we have the main power flow coming from the battery (or fusebox terminal in my pic above) through the relay and then to the foglights. We also have a sensor wire connected to the trigger device---in this case, the #4 parking light fuse.
When the parking lights are off, the relay remains in an open position preventing power from flowing from the battery to the fogs. When you turn on the parking lights, the relay senses the power on the signal wire and closes the circuit from the battery to the fogs, allowing power to flow to the foglights (or ballasts if you have HIDs).
Hope this helps some.
To answer your specific question, the Add-A-Fuse connects to the signal wire of the relay.
#144
H11 get the glass housing not plastic which I was told that can melt and deform the housing because its plastic and not glass. I think it comes with relay already.
#150
TEAM_SONIC
Is this what you got?
http://www.k2motor.com/lf-acd034oem.html
Also are you sure H11 is the same as 9006? If, so I'm surprised.
#152
Former Sponsor
Why don't you do what I did and email the guy on ebay before you buy and ask if the lens is glass or plastic. I have done about 5 of these jobs and they take a-lot of time and patients. Wiring came from accord fogs and each had two wires (black for ground and other is positive). I just spliced each power and ground to the factory fogs( black to black and I believe its blue/yellow for positive). You can leave the factory fogs or cut the wire and run them directly to the switch. So the factory switch can run both accord and factory fogs or just accord fogs.
DO NOT WIRE THEM TO THE PARKING LIGHTS. god forbid you leave the parking lights on and you leave your car and they blink you will burn your HIDs if you plan on making the fogs HID.
#153
TEAM_SONIC
#154
#155
Former Sponsor
I will try and take some but why don't you just use the old trial and error and unplug the wire you think is the fog and turn them on. If fogs come on the. Plug back in untill the wire you unplugged is it. I believe it's the blue/yellow wire with the black. More toward the grille .
As for MA. It's not about wiring them, it's about knowing how to dremel them to fit perfectly.
#156
TEAM_SONIC
Since you have done about five of these, can you please tell me how much you would charge me if you installed the fogs on my TL? Thanks.
#158
hey, i need alittle help, i just got my kit in the mail but my harness is totally different, i just need help installing it without a switch, heres a picture of the harness wiring i got. it comes with 2 relays wired in and also theres 2 yellows, 1 red, 1 light blue and 1 dark blue, 1 black, i know the black is ground and red is power from the battery, i just dont know where the 2 yellows and 2 blues go,
#159
Former Sponsor
A you need to connect the power into the fog lights and that that red and black wire and connect them to the stock fogs. Black to black (ground) and red to i believe yellow/blue (power) and you shall have light. Wiring is not so much hard as it is to install them. Its hard to explain but take baby steps and take your time.
#160
yah im so lost right now, ive been playing around wtih the harness and it think i mite take out 1 relay, they are only connected by a ground wire, so if i just use 1 relay, the 4 wires coming out is a black for ground, 1 red to power the lights, another red that i guess will go to the battery, and then a yellow that ill hook into the fuse box, does that sound right?
