DIY Alignment Question
So I bought all the stuff to do my alignment on my car. Going to he using toe plates with camber / caster measurements. I've done alignments for years using Hunter machines, but never using toe plates. I no longer have a shop or access to the alignment machines.
My question is with setting the toe and having a straight thrust line and steering wheel. How do you know which side needs adjusted? I get that you can make the total toe to spec, but that could still make the thrust line off or the steering wheel off centered. Am I just missing something simple or what? The alignment machines tell you which side to adjust to make it straight lol. I was spoiled for too many years!
Thanks!
Thanks!
