Alignment -Toe In Question
Old Mar 8, 2006 | 12:15 AM
crvlvr's Avatar
Can anyone help me convert the alignment specifcation from mm to degrees? the a-spec installation recommends the fallowing:
Front: 0mm+-2mm
Rear: in 2mm+-2mm
The alignment shop I went to has a machine that measures it in degrees. how does the above convert to degrees?
The specs the it offers for the TL is as follows:
Front: -0.08deg to +0.08deg
Rear: 0.00deg to +0.16deg
Are these correct?
TIA
Old Mar 8, 2006 | 08:54 AM
Ron A's Avatar
Administrator
Toe-in specs are given in mm, and camber and caster specs are given in degrees, so there is no conversion necessary. The alignment shop will know which one to adjust by which measurement is given.
The standard alignment specs are given in the back of your owner's manual under Specifications.
Old Mar 8, 2006 | 01:00 PM
crvlvr's Avatar
Ron A, thanks.. newer computerized alignment machines seem to measure toe in degrees. i here is one website that shows conversion http://www.pelicanparts.com/techarti...ome_toe_in.htm
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
juanrl
Sep 29, 2015 03:25 AM
navtool.com
Sep 25, 2015 05:15 PM
