Disable trunk light??
Has anyone found a way to turn off the trunk light with the trunk open??... I removed the trunk light module but for some reason this still caused battery drain. Because I use the trunk alot I would like to be able to leave the trunk open in my garage without running down the battery....any ideas??
you can just pop out the bulb and easily slide it back in when you want to use it. why do you keep the trunk open for so long? it would take about a day before it drained the battery
Re: Disable trunk light??
What are you doing in the trunk?
What's a TL?
Re: Re: Disable trunk light??
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
handsom-hustla
11-13-2015 05:04 PM
