Disable the service reminder
My service reminder just came on and it's really annoying me. Is there any way to disable it prior to taking it in?
AZ Community Team
Received 7,771 Likes
Sure, just reset it.
Good idea? Maybe not, but it'll stop bugging you.
AZ Community Team
Originally Posted by rbf351
BTW - Phoenixville, PA. Home of the Epicurian, which has the MOST IMPRESSIVE beer menu I have ever seen. Love that place. Celbrator Dopple Bock -
Originally Posted by Bearcat94
I actually don't know how to reset it (yet). But RTFM is a good start; There is also a thread on this that was up just recently.
Try the Draughting Room in Exton. Equally good beer menu and better food!
~Da Nocturnal Cheetah~
How to reset the maintenance reminder...
This may be more than you want to know, but here's the full procedure to reset the MID display, and also info at the bottom about other service reminders when you manually reset the MID yourself.
(The procedure on page 196 (of the 2004 owner's manual, and probably for later models also but if anyone has a later model with the correct procedure please let me know) of the manual is incorrect. In paragraph 3a of the manual, the requirement to hold the button for 10 seconds the second time it is pressed is omitted. If this is not done, the display will not reset.)
1. Turn the ignition switch to ON
2. Select Trip A or Trip B (You can use either one, so if you are using one to record data for something, use the other one to reset the Oil Life Indicator).
3. Press the < or > button repeatedly until the oil life is displayed.
4. Press and hold the Select/Reset button for 10 seconds. The Multi-Information Display will ask for a confirmation.
From the service manual, page 3-6: (NOTE: This information is not in the owners manual.
NOTE: If you are resetting the display when the oil life is more than 15%, the maintenance message "Service Due Soon" will be displayed. Make sure the maintenance items requiring service have been performed before resetting the display.
So this means if you change your oil before the 15% Service Due Soon is displayed, and you go to reset the display, if there are other items to be serviced, they will show up on the display, and if you clear the display the MID will take this to mean that you performed the required service.
To clear the display:
After you get that service screen hold the reset/select for another 10 seconds.
It will then ask you if you want to reset.
Press the reset/select or the YES button (I forget which), and the MID will be reset
The statement from the service manual is a little vague, and I think they meant to say that if other items require service, the message "Service Due Soon" will be displayed, since if there is nothing else requiring service there would be no need for the message.
There is an explanation of how the MID works in the Acura Service News for September 2005 http://www.in.honda.com/Rjanisis/pubs/SN/B050900.PDF
and more about how you will get additional reminders when resetting the MID before it reaches 15% in the Acura Service News for September 2006: http://www.in.honda.com/Rjanisis/pubs/SN/B060900.PDF
- a. If you are sure you want to reset the display, press the Select/Reset button for 10 seconds again. (This is the part omitted from the manual.)
- b. If you do not want to reset the display, press the < or > button to select “Cancel”
