Difference between 04-06 ASPEC side skirts and 07-08
What is the difference between these side skirts and can either fit on a 04-06 TL? Are the ASPEC side skirts actual bigger height wise then the OEM stock ones? meaning.. will they make the vehicles appearence lower?
thanks
thanks
94 DC4 RS LSV/Turbo
07-08 Type S side skirts NON ASPEC are slightly diff to 04-06 stock side skirts
ASPECS ARE ALL THE SAME (Color is the variance in part numbers only)
Doesn't matter, all 3G TL side skirts should fit perfectly.
Now before I assume, are you talking about the Type-S, or 07/08 base?
They are all the same.
Yes, but for ALL A-SPEC side skirts, whether they are for the base or Type-S or not, they are all the same.
I don't think you understand what I'm trying to say. ALL 04-08 A-Spec side skirts are the same.
08 MDX, 04 TL (sold)
Anyone have a good photo showing the Type-S skirts and highlighting what makes them different?
OP, it sounds to me like you want Aspec side-skirts -- choice 3 from the list above. These are the same for all years 2004-2008.
I give up.
94 DC4 RS LSV/Turbo
I did not realize that the Type-S non-Aspec had different side skirts than a base model. This might be what the OP is still hung up on.
THEY ALL THE SAME AS MENTIONED PRIOR
I'm Craig
Stock BASE TL side skirt. No flare.
A-Spec TL side skirt. Most flare.
acurajj
02-14-2016 02:28 PM
09-14-2015 10:48 AM
09-04-2015 08:03 AM
