Dashboard
Old Sep 13, 2014 | 06:16 PM
jipp2296's Avatar
5th Gear
Dashboard
My airbags deployed on my acura tl 2004 there's a hole. In my dash board do I need to replace the entire dashboard or just a part of it and also do you have any advice in doing it like to do it quicker
Old Sep 13, 2014 | 08:53 PM
paperboy42190's Avatar
whole dash replacement is needed. good luck, this isnt something you can rush through.
https://acurazine.com/forums/problem...images-909544/
Old Sep 14, 2014 | 12:10 PM
jipp2296's Avatar
5th Gear
But what do I do with the Vin number since it's attached to the old dashboard? Help pleaseeee
Old Sep 14, 2014 | 04:00 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Threads like this make me wonder if the question being asked is legit. Most of modern day vehicles have the passenger airbag deploy in a perforated section under the dashboard that is designed to break open just as your drivers airbag is designed to function in an event of an airbag deployment. When the passenger airbag deploys the dashboard needs replacement. You can't patch, glue or McGiver the dashboard together and just install a new airbag.
The dashboard will need to be replaced as an entire unit as well as the SRS module and seat belt tensioners. The VIN is by far the least of your worries. It's held in by rivets, which are drilled out and put on the new dashboard.
Old Sep 15, 2014 | 01:33 AM
^+1
Old Sep 16, 2014 | 05:47 PM
jipp2296's Avatar
5th Gear
Does it need to be a dashboard from a tl with navi or it could be from one with no navigation system on it or do they have different wiring
Old Sep 16, 2014 | 06:24 PM
jipp2296's Avatar
5th Gear
Because I bought a dashboard from the same car but no navi on the other one and now my mechanic says that I need some wires
Old Sep 19, 2014 | 01:07 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
From my understanding, the dashboard from 2004-2008 varies only with a sunlight sensor. I believe it's in a different position on 2007-2008 or there's another senor by the drivers side.. I remember seeing something different on my friends Type-S dashboard (extra sensor) which isn't there on my 2004. Regardless, that's the only issue I know. From navi to non navi it wouldn't matter because all you need is the dashboard cover. Everything under the dashboard like vents, wiring harness, airbag, metal support frame gets swapped over..
Old Sep 19, 2014 | 01:27 PM
screaminz28's Avatar
If you dont want to drop the cash on a complete dash for tons of money, you could get one of these:
Coverlay dash cover
Coverlay Mfg| Dash Cover Coverlay 30-408LL-DBL
From a thread here about the cracked dash - Member pics:
https://acurazine.com/forums/problem.../#post14890087
Old Sep 19, 2014 | 01:56 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Coverlay dash cover
Thanks for the information on dashboard covers, which are fine for cracked dashboards however in his case his airbag deployed and has a giant hole in the dash.. not sure how this is going to help him..
Old Sep 19, 2014 | 02:08 PM
it'll help him by covering the hole
Old Sep 19, 2014 | 02:09 PM
Yeah, I thought that was kinda obvious. He asked about the dash - not about a new airbag. Even if you replace the airbag, you'd still have a hole in the dash.
Not sure how it isn't sure that is going to help him..
Old Sep 20, 2014 | 01:44 PM
jipp2296's Avatar
5th Gear
So basically i have to change all the wires from the old dashboard to the one i just got? Im planning to do it tomorrow so anything you guys know will help!]
Old Sep 20, 2014 | 04:59 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
There's a thread posted somewhere in this section (3rd gen TL) of someone replacing their dashboard with instructions and pictures.
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Sep 14, 2015 10:09 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
wendtdc13
1G RDX Problems & Fixes
Aug 30, 2015 06:39 PM
chef chris
Wash & Wax
Jun 3, 2003 08:57 PM
