A couple of questions...
How many of you occasionally feel a fairly significant pull to the left when braking?
Also, how many of you have a steering wheel that is slightly off to the right when tracking straight?
I do not have either.
Mike
Mike
an Acura has-been
The pull to the right could be the crappy BS tires, several have posted that the dealer switch sides with the tires then the car pulled to the left, this is not an uncommon problem (but not normal either and tires should be replaced) with tires from what I have read on tire sites and speaking with tire shops.
The pull could be the tires I suppose. It doesn't seem to be consistent. I'll try to focus on whether or not the road is uneven when this occurs.
As to the wheel being off to the right, it is clearly mounted that way. Just wondered how common it was and also whether it could be fixed.
I recall someone mentioning the steering wheel problem but couldn't find the thread.
Chief TL Aviator
Youngmic,
To fix the steering wheel issue, have your dealer do the following:
1) Check tire pressure. Mine was too high ...
2) Do a full 4 - wheel alignment
3) Adjust the steering one "tooth" ("spline") to the left.
Good Luck!
Good Luck!
AcuraKidd
09-25-2015 11:18 PM
