coolant drips?
coolant drips?
’07 TL-S with 2,300 miles. I noticed some spots of coolant (about 15 nickel size drips) on my garage floor and some underbody parts with coolant on them. Cause for concern or “normal”, I know most reservoirs have a blow off tube but not sure how this car is or why it would need relief with 30°-50°F temps.
Overflow from the reserve tank?
Registered but harmless
Received 1,107 Likes
It's a cause for concern-- check the coolant level with the engine cold by opening up the radiator cap (in addition to checking the overflow reservoir) to make sure you have coolant in the radiator. It sounds like you have a leak to me. You shouldn't be getting any overflow on the undercarriage, unless the coolant reservoir is really overfilled.
WDP Director of R & D
Unless your reservoir is plum full it's probably not coming from there. I would be heading straight to the dealership for them to investigate. Could be a bad water-pump, head gasket or as minor as a bad hose clamp. Stuff happens with mechanical/mass produced items
Hate to see you get stranded due to overheating etc..
AZ Community Team
Received 7,771 Likes
I agree - not normal. Get it checked.
Well if you were told it would be ideal to not drive the car, then they should provide you a free loaner. You should be tooling around in their iron and not yours. What if the power steering failed and well caused a mishap. Sure the chances are extremely rare, but ask for a loaner since you are concerned about the reliability of the car until it is repaired.
IBankMouse
06-13-2020 12:53 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
