Coolant
Old 04-09-2010 | 12:49 AM
meowevil's Avatar
Coolant
Which engine coolant should I put into my car? I just noticed it is little bit below the "min" requirement, and I am not close to any honda/acura dealership
Old 04-09-2010 | 01:14 AM
01tl4tl's Avatar
if its an inch or 2 down just add clean water- not enough dilution to worry about
the real concern is where has this coolant gone?- it should never use any- just moves back and forth between the res bottle and the radiator as temps change- expansion of fluid etc
Make sure the tube attached inside CAP of res bottle is solidly attached-
they like to fall off and into the res bottle- without that hose the system wont work and may lose coolant from bottle
If thats ok, start looking around the floor under car- under water pump- and radiator edges - front of rad for rock hit etc
Pressure tester avail for loan at parts stores will simulate operating pressure and show leaks
good luck!
Old 04-09-2010 | 01:22 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Any type of 50/50 mix should be good.
Old 04-09-2010 | 03:14 AM
SpiderX1016's Avatar
I'd top it off with distilled water. Mix a little coolant in.
Old 04-09-2010 | 06:37 AM
SouthernBoy's Avatar
Registered Member
Around five or six years ago, Road Rage posted some very good info about what fluids and products from Honda/Acura you should be using in your car and he gave the reasons for this. Automatic transmission fluid and coolant were two of them on his list. So I have two gallons of Honda/Acura premix coolant in my garage for those times when I have to add a little to the tank.
If you want to know his reasons (I think it had to do with seals and rust inhibitors) try a search or perhaps PM him for them. When you get your answers, do everyone a favor and post them if you would.
Old 04-09-2010 | 07:55 AM
vinnier6's Avatar
whatever coolant you want....it is that simple, my choice is the prestone 50/50...but keep in mind, you are paying for a half gallon of water!!
Old 04-09-2010 | 10:41 AM
01tl4tl's Avatar
distilled water~
read the label on bottle- Approved for Acura is what you are looking for
Most are now universal and meet our spec- its something about silicates in the fluid iirc, have them or not..that would affect seals
cycdaniel
12-17-2019 10:58 AM
merc009
01-27-2016 10:34 AM
LeVeL
10-18-2015 04:19 PM
ROSSARONIE
10-02-2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
Quick Reply: Coolant
