comptech exhaust dyno
Old Nov 4, 2004 | 03:16 PM
TheOne305's Avatar
I didnt see a thread on the info but i jst chk and they have it now to view on their site.
http://www.comptechusa.com/
Old Nov 4, 2004 | 03:26 PM
PoochaKannInc's Avatar
Shift_faster
Good find thanks!
Here is the specific link.
http://www.comptechusa.com/images/dy...atbackDyno.pdf
Old Nov 4, 2004 | 03:39 PM
leeo's Avatar
wow , only 6hp huh..That's not very impressive , i wonder what the dnyo is for just removing the resonators from the exhaust..Cause im sure that it should be within that same range..
Old Nov 4, 2004 | 04:33 PM
Thorin78's Avatar
Previous Owner
maybe i don't know how to read, i thought the stock hp is 270
Old Nov 4, 2004 | 04:37 PM
cM3go's Avatar
at the flywheel, wheel HP will be significantly lower, in this case, around 225
good news is, it seems to increase low end torque, as much as 10 ft lbs in some cases... but damn those tips!
Old Nov 4, 2004 | 05:21 PM
go4heat's Avatar
The stickiest of the icky
or in most cases...
but damn those $$$$$$$$$$$!!!!!!!!
Old Nov 4, 2004 | 06:03 PM
Road Rage's Avatar
Not a Blowhole
1) The Comptech has a resonator too - not that that is a bad thing.
2) Peak HP is 7.5 at 6200 - not much to play with
3) The 10 ft/lbs just off idle looks odd, it spikes at 10, but the area on either side is only a bit more than half that.
These numbers are not much better than normal variances one would attribute to any 2 runs. Condisering that most companies usually inflate things a bit (sales puffery), and nothing is listed about the test conditions (air temp, coolant temp, relative humidity, etc) I am not impressed at all, nor moved to order one.
I would like to know the weight of the CompTech vs. Stock. Anyone know??
I have sold C'tech for a long time, and the quality is there, and my 2002 Type-S had headers and CB, and picked up a few ponies, but it hardly made a dent in the overall performance profile; nor would one expect it to do so, considering the single digits gains, and the peak HP close to redline. Hey, anyone has to have one, PM me for info.
Old Nov 4, 2004 | 10:21 PM
Nitrotiger's Avatar
was that an auto or 6 speed
Old Nov 5, 2004 | 12:09 AM
TheOne305's Avatar
Comptech dyno shows peak was at basicly redline.I thought our peak was 6200 then the ecu starts to rob our power to redline but comptech hights gains are at redline its showed 236whp
Old Nov 5, 2004 | 01:04 AM
cantadaniel's Avatar
$1000+ = 6hp??? what kinda formula is it???damn
Old Nov 5, 2004 | 09:28 AM
Nitrotiger's Avatar
Not a good one i have the six speed and a dropin K+n gave me 5whp i have 233.9whp ahh i think ill pass on the $1000.00 dollar upgrade and ugly exhaust tips
Old Nov 5, 2004 | 09:42 AM
livnforyou's Avatar
the picture on the comptech website only gives you a close up view of the exhaust from the back of the car. anyone have pictures to show the exahust from 10 feet out? i just want to see the overall look from the back to see if the round exhausts look better than the stock rectangle ones.
Old Nov 5, 2004 | 01:24 PM
TheOne305's Avatar
if ya do a search there is a pic of a NBP about 20 ft or less at an angle i believe.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
joflewbyu2
Oct 8, 2015 11:16 AM
prbori
Sep 27, 2015 01:37 AM
