Combination of mods has significantly decreased MPGs
I have an 07 type-S with 136k miles. Since I purchased the car in February I have done a few minor modifications that I believe have lowered the gas mileage little slice by little slice. Here's what I have done:
-Switched to 5w-30 Red Line full synthetic oil
-Switched to all Red Line type-F ATF
-Switched stock tires (235/45-17) to 255/40-17.
-Switched the air filter to a K&N air filter (regret doing this)
After doing a 1200 mile road trip to the outer banks coming from up north and doing nearly ALL highway driving at ~65mph, I think it's safe to say that the minor modifications that I have done have decreased my MPG. I only averaged 29mpg on the way down. Same with the way back after resetting the MPG counter to see if I could do better. I had a trunk full of luggage and a passenger and put Shell V-power in my car the entire trip.
Tire pressure was checked in the morning in the garage and blown up at the same time to ensure that cold tire pressure was at 35psi front and 32psi rear. Same was done on the way home.
well the wider tires arent helping gas miliage, but it seems like the rest of it would be enough to offset. what kind of miliage were you getting prior to these mods? changed your plugs recently?
wont ride as nice, especially with a 40 series, but for road trips I need more miliage on I bump up the pressures to 40f & 35r.
^^^lol.
Had the weirdest trip this weekend...
Ohio->NYC. Got 30 MPG going up but struggled to get 26~27MPG (back and forth on the gauge) coming back. The only difference was that I brought back 2 chocolate bars ($8/ea in NYC) and I took an empty camera, but came back with the memory chip loaded with 1000+ photos (maybe make it weigh a bit more from all the electrons)
Generally I've not seen a variation greater than 1MPG for long trips - typically I get 28~29. No mods of any sort to the car.
Have a look at this post:
https://acurazine.com/forums/showpos...1&postcount=83
As for the plugs, I'm not really sure when they were changed. I need to call the dealership that the car was serviced and check and see if they did them when they changed the timing belt and serpentine belt.
As for the luggage weight, if I had to guess I would say that there was close to 100lbs of weight if that.
The tires that I had on the car before were bridgestone blizzaks and I would get north of 30mpg easily. I purposely tried to drive with MPGs in mind on this vacation and road trip and the best I could get was what I got.
Received 3,824 Likes
Tires and fully loaded trunk + another passenger.
the overexplainer
yep. Some say the rule of thumb is every 100 lbs is another 1 mpg lost. You already lost at least 2 with just luggage and the passenger.
that and the wider tires aren't helping.
BrownBuck
Man if i sniffed 30 i would be happy...i don't drive that aggressive and the best i can get is 26ish....i usually even out and sit at 25 high+city...so if i do ALL highway i can imagine getting 30ish...altho i've yet to go on a trip and confirm that.
What do you avg city+highway usually?
check your MID
You installed thicker oil, thicker atf, wider tires and an oil-soaked air-filter and your wondering why your mpgs went down? If MPG's were such a major concern, you probably should not have done ANY of that.
I noticed an instant 1-2 mpg loss in my daily commute going from M1 5w20 to M1 0w30. I went from 29 every tank to 27 every tank. I know most say you won't see any difference between different oil viscosity, but this sure was an odd coincidence.
The following 2 users liked this post by 94eg!:
shenrie (05-31-2012),
Undying Dreams (05-31-2012)
BrownBuck
huh? don't understand why ur talking about that?
My MPG for City is around 17-20 and Highway is around 27...and i avg usually(majority highway driving) 25 on the dot...SOMETIMES 26 if i drive more freeway...i've never tried to drive the whole tank on the freeway yet so i don't know what my legit highway mpg is according to the MID.
Moved to the LOU
takin care of Business in
Received 4,732 Likes
Yes Redline 5w-30 will yield a little less (marginally) as it is a very thick oil...almost as thick as other brands 5w-40....i used to run 5w30 from Mobil 1 but when i switched to mobil 1 i went with 5w20 (first fill was 5w30 and recently switched to 5w20)....
the ATF shud affect your gas mileage....weight affects MPG....
i am fully bolted in and i used to get 33MPG highway....when i got my exhaust my MPG went out the window....started getting 29-30MPG highway....with weight loss i went back upto 32-33MPG....
you should also check the elevation....i used to drive from KC to STL and get higher gas mileage when i drove TO STL as STL is at a lower elevation as compared to KC....
PS: I always traveled with a passenger who weighs 115 lbs and some stuff....and i always get 30+ MPG highway
AZ Community Team
Received 7,770 Likes
This.
You may think I'm kidding, but I'm not.
OH --> NYC is more downhill and more likely with the wind than the return trip. Changes in temp can be a factor as well.
Edit:
FWIW, I get ~30-ish highway MPG in my '07 TL-S. Without 'excess' weight in the car.
Edit:
I always noted just the opposite...although I attribute the difference in 91 octane on the trip to STL and 93 going home. These days I usually try to stop in Columbia for fuel since that is the furthest West 93 octane goes on I-70 in MO for the most part.
+1 for wider tires as they increase rolling resistance. I drive a 02 CL-S and I get 29-31mpg at 72mph. Any mod that lets the engine breathe easier will by default affect gas milage as you need more fuel to go with that air.....
Every tire is going to be different which is why I gave my tire info. Those Pilot A/S Plus tires seem to wear much faster in the back on the TL. There's a rumor that this was one of the reasons Costco stopped selling them- I haven't checked but notice they're not in the Carlsbad warehouse the last time I checked. I'll be getting Continentals my next time.
extra weight doesn't help out with the gas mileage.
Any mpg loss has nothing to do with the fluids used. Its weight and tires coupled with the fact that unless you do a round trip calculation its meaningless. Weight of tires, rolling resistance and a very real aerodynamic penalty are causing this. Redline has significantly less friction from the zddp and moly along with the base oil and better ring seal which overrides any immeasurable mpg penalty from the heavier weight. Oil weight is just a small part of the picture and once warm theres a very slight difference in weight.
I started off in Columbus, OH with 3/4 tank of unknown fuel, all tires around 34psi, what appears to be fairly old cheap Valvoline oil, a single passenger and nothing else. A/C was set to Lo most of the time, fan speed 1, radio/headlights on the whole way. 55-65MPH highway speeds, limited traffic prior/after that. This was with a 07 6MT Type-S, almost entirely stock, no drafting.
It looks like its settled on 24-26 now with lots of short trips and traffic.
InFaMouSLink
10-27-2015 06:52 PM
