Code P-0154
Old Oct 22, 2018 | 09:30 PM
lumn8's Avatar
Code P-0154
Hello- Girlfriend has Code P0154 on a 2008 TL- Looks like Bank 2 Sensor 1 failed. Do i need any special Tools? Any recommendations of where to buy this part? is it hard to get to? thank you. Very Mechanical inclined.
Old Oct 22, 2018 | 10:30 PM
Algavin's Avatar
If I'm recalling correctly, that is literally right there next to the hood latch as you pop the top. It does reasonably need an O2 socket (for a socket wrench) to let you slot it over the sensor body with the wires still on it. Very simple job, takes you maybe 5 minutes. My Bank 1 Sensor 1 went bad and I replaced the B2S1 while I was at it. Go with Denso only. I tried another brand and I had to have them replace it for me once and it still wouldn't work, so I've changed the damn thing 3 times. I just grabbed it from amazon.
Someone please correct me if I'm recalling incorrectly.
Old Oct 23, 2018 | 08:21 AM
Jackass's Avatar
5 minutes....if it will break free that easily...mine did not....just took a few days of soaking it with PB Blaster before going to bed once things cooled down. Yes, you will need an O2 socket, under $15 on Amazon. Denso or NTK should be fine. My OEM was an NTK, but I replaced with a Denso.
Old Oct 23, 2018 | 12:44 PM
lumn8's Avatar
Thank you- is there a specific Denso Model #
Old Oct 23, 2018 | 11:26 PM
RyoKaii's Avatar
5th Gear
I bought my denso o2 sensor at Rockauto. The model number is DENSO 2345010.
piggydog
Feb 11, 2010 11:05 AM
jnherdendorf
2G CL Problems & Fixes
14
Dec 10, 2009 08:42 AM
aznriceball
1G TSX Problems & Fixes
Aug 18, 2009 10:15 PM
TLMAK
Feb 19, 2008 03:59 PM
tsxnation
Apr 19, 2007 03:30 PM
