Clogged Brake Line
Old Jul 29, 2015 | 09:28 AM
Turbonut's Avatar
Clogged Brake Line
Been some questions about sticking brakes, so thought I'd post a recent problem, although not on the TL.
Daughter was on the way home from work in her Maxima, called and complained about the car pulling hard right and a burning smell. Classic sticking brakes. Loaded up tools and headed about 15 minutes from the house. Found right front to be the problem, much hotter than the others. Jacked up the car, tried to push the piston in, no go. Opened the bleeder and got the pads away from the rotor. Drove home using the hand brake.
Once home and in the garage, removed the brake hose and pushed a thin wire through until it stopped at the clog at which point I cut the line in half. As you can see the hose is completely clogged right at the hose brace. Some may split inside and cause a clog, but many just built up corrosion at the brace area:
Not a great picture, but:
Old Jul 29, 2015 | 09:31 AM
Jesstzn's Avatar
This from not changing the fluid? Isn't some fluids now days hydroscopic? Pulling water from the air and rusting the lines from the inside.
Old Jul 29, 2015 | 09:34 AM
I believe all brake fluid is hygroscopic hence the need for the time-based service interval (3 years).
Old Jul 29, 2015 | 03:50 PM
Turbonut's Avatar
I also recommend that the brake fluid should be flushed every 3 years.
The Maxima was never flushed during it's 16 year, 250,000 mile travel, and it shows!!!!!!
Old Jul 31, 2015 | 10:28 AM
Vlad_Type_S's Avatar
Registered Bike Offender
Haha this is a fantastic photo, thanks for sharing. Glad nobody was hurt! Now where are all those people that say you don't need to change brake fluid.
Probably on facebook.
Old Jul 31, 2015 | 10:38 AM
guitarplayer16's Avatar
Considering Facebook has 1.5 billion users, you're not wrong.
Old Jul 31, 2015 | 10:45 AM
I was poking fun of the various Acura/TL groups and how much misinformation is spread through there.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
