Clearing headlights help
Old Jan 6, 2009 | 08:19 PM
TLNY04's Avatar
Im thinking about clearing my own headlights but i was wondering is it possible to use a heat gun to losen up the sealant?
thanks
Old Jan 6, 2009 | 08:22 PM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
its posible but not recommended. i had alot of doubts about putting it in the oven as well but it came out great. did it last week. 20 minutes at 200 degrees no preheat. you'll be good.
Old Jan 6, 2009 | 09:53 PM
TLNY04's Avatar
ok so how about this.... How about putting them in my 500 degree pizza oven at my shop? maybe for like 30 seconds?
Old Jan 6, 2009 | 10:01 PM
05ASPEC TL's Avatar
lol do it and you wont have no headlights. jus follow no preheat and 200 degrees 20 min then your golden.
Old Jan 6, 2009 | 10:06 PM
Blazing GT's Avatar
follow the rules.
don't invent. haha
CHiNaMaN440's Avatar
04 "NBP TL" 6mt
just add pepporoni and sausage and your cooking!
Old Jan 6, 2009 | 10:12 PM
TLNY04's Avatar
Lol i know.... alright i guess just put it in a regular oven no pre heat for 20 minutes... do i have to put a wet rag under/ over it? and do u think i would be able to do do this withought messing up my headlights i already went out and bought the sealant and black plastic spray paint
Old Jan 6, 2009 | 10:14 PM
EVOLICARUS's Avatar
so many threads on this.. do a search or go to the 3g garage.. pics and everything
Old Jan 6, 2009 | 10:16 PM
TLNY04's Avatar
anybody close to me just feel like doing them 1 day
Old Jan 6, 2009 | 10:17 PM
04 "NBP TL" 6mt
Lay a wet towel underneath and make sure any of the plastic isn't touching the oven. Preheat to 250 and bake for about 10min.
Just take your time doing it. Once you get the headlight apart, everything is cake from there. Wear gloves and carefull not to leave any residue on the headlight
Old Jan 7, 2009 | 12:11 AM
daniel123588's Avatar
I used a heat gun and a hair dryer and also two other people to pry apart and put back together the headlights BUT I recommend using the oven as well. Sadly my headlights would not fit in the oven. using the oven will heat the sealant all at once so taking apart and putting together is WAY easier. Good luck.
Old Jan 7, 2009 | 12:19 AM
TLNY04's Avatar
is there a specific type of paint that i have to use though i just went to home depot and got a black spray paint for plastic... does it have to be like heat resistant or does that not matter
Old Jan 7, 2009 | 07:46 PM
Etohprn247's Avatar
KoolKatz..
how about when putting back on? reheat ....again?
Old Jan 7, 2009 | 08:50 PM
tbdefense20's Avatar
FL 04 dgp TL
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-blacked-cleared-headlights-3g-garage-g046-589746/
here is the diy
Old Jan 7, 2009 | 08:57 PM
JCL622's Avatar
A-spec steering wheel ftw
i can help but you have to do the bumper removal....after all these years i still suck....i jsut helped do my friends at home and she was better than i was at pulling off the bumper LOL... (wow i can't believe i just admitted that)..
it's really straight forward actually, i need to rebake one of mine, you help me pull my front off too and i'll come help you with yours LOL
Old Jan 11, 2009 | 03:59 PM
05ASPEC TL's Avatar
what happen to your other headlight?
Old Jan 11, 2009 | 05:44 PM
Trew's Avatar
The wet towel will help prevent the headlight from melting while laying on the iron grates inside the oven.
When putting back on press the assembly together as best as you could (start with the outside corner of the light and work your way back to the middle). After you get it in as far as you can, reheat for 10 minutes, but don't use a wet towel. Use a dry towel instead. EdLuv143 and I learned this the hard way today after the heat caused moist air to leak into the headlight from evaporation. We had to pull the signal bulb out of the sealed assembly and let it set out in the sun for a little while to dry out.
Other than this, read the DIYs. They have everything you need to know.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
jmaxima03
Sep 27, 2015 10:22 AM
