Cleared/painted headlights group buy
Old May 23, 2008 | 11:08 AM
  #281
izmyttz's Avatar
that's because that isn't an 08 headlight..it's an 04-06. I had the same problem. When I bought my 07-08 TL-s Headlights I had to buy the bulb holders for the 07-08 because they are different than my 06 was. If you got those headlights in the group buy then you got the wrong year.
Originally Posted by jokerunm
I don't get it.....both the 07-08 TL and the Type-S are suppose to accept the same bulbs correct? Well, here is the bulb from the 07 Type-S resting on top of the hole of the headlight from an 08 TL. Bulb is too big for the hole.......much less the socket. The socket on the Type-S will not clip onto the TL headlights because the hole is too small.
Old May 23, 2008 | 11:19 AM
  #282
jokerunm's Avatar
They can't be 06 headlights. The design was changed after 07, the fogs where moved off the lights and the DRL have a circular enclosure, reflector. So two circles, vs 1 circle and 1 square for the 06 lights. So it's pretty easy to tell the difference.
Old May 23, 2008 | 05:43 PM
  #283
lights's Avatar
Engineer
from what it looks like....
the 07 base TL have amber diffusers, so does that mean they use 7443 bulbs as well for signals??
the type s headlights have cleared diffusers, that's why they switched out the 7443 bulbs since 7443 amber bulbs aren't common.
can someone confirm??
Old May 24, 2008 | 10:24 AM
  #284
izmyttz's Avatar
i was a group buy. There were so many headlights I bet they just used pieces from all of them to put them back together. The rear part of the headlights are the same except for the bulb holder configurations. Sounds like even if you get a 7443 bulb then your still going to need the 7443 bulb holder from Acura..and even then you're plug won't fit the bulb holder. you'd have to rig it up with wires and wire taps.
Old May 24, 2008 | 10:54 AM
  #285
jokerunm's Avatar
what group buy is this?
Old May 24, 2008 | 11:08 AM
  #286
jokerunm's Avatar
Originally Posted by KimboBread
oh yea the Sylvania Silverstar 1157 bulbs that I purchased did not fit!! The light housing for the car was like a horizontal cartridge fit and the ends of the Sylvania's I purchased were circular. But I was pressed for time so I had to leave the regular bulbs in! Also have an issue where my DRLs will not come on, only my HIDS are on when I turn my lights on now.
Hmmm....the 1157 bulbs didn't fit hugh? I'm think I'm seeing a connection here.
JnC, are the lights you sent me originally from KimboBread's car?
Old May 24, 2008 | 12:14 PM
  #287
JnC's Avatar
JnC
Former Sponsor
Yes the lights did come from kimbo,
here is what the 1157 looks like
and here is what a 7443 looks like
I think the base model uses 7443 since the bulb doesnt need to be amber (cause of the amber defuser) and in case of the type S they are using 1157 bulb since 1157s have amber colored glass rather than clear glass, this because of the clear defuser as "lights" stated.
So if thats the case then the 1157 wont fit the base model 07-08 headlights since its bigger in size than the 7443 bulb.
The lights that I sent to kimbo were indeed base model ones thats why the 1157 didnt fit the housing that he had with him and that indeed is the reason why its not fitting the headlights I sent you jokerunm since you have a type S.
Old May 24, 2008 | 12:16 PM
  #288
JnC's Avatar
JnC
Former Sponsor
BTW slimboogie your headlights went out yesterday and should be with you before the end of the week.
Old May 24, 2008 | 12:22 PM
  #289
JnC's Avatar
JnC
Former Sponsor
What you are saying is that I use backs and lenses from different headlights? In that case no, that doesnt happen. I open a set and work on it and reseal it using all the same components.
Here is a break down for every one,
04 headlights are the same as 05 headlights, they both use same sized ballast and most of them have DOT step style projectors.
06 headlights are same as the 04-05 but the only difference is that they ballast used is smaller, so 06 headlights wont fit an 04-05 model. All 06 have DOT slope style cut off.
07-08 base model headlights have the DRLs as you know, plus chrome inner insert, amber defuser and the same ballast as the 06 model.
07-08 Type S, same ballast as 06 and 07-08 base model, clear defuser and most of the insert is painted glossy black. Both base and type S model headlights use DOT slope style cut off.
DOT step
________________|''''''''''''''''''''''''''''''''' '''''''''''''''''''
DOT slope
________________/'''''''''''''''''''''''''''''''''''''''''''''''''' '
Bulbs
HID main beam
D2S Osram 60404 bulbs for all models.
Turn signal
04: 7443
05: 7443
06: 7443
07 base: 7443
07 Type S: 1157
08 base : 7443
08 Type S: 1157
Fogs for 04-05 and 06 models use 9006 bulbs.
Old May 24, 2008 | 05:45 PM
  #290
slimboogie's Avatar
4 shizzle
Old May 25, 2008 | 12:13 AM
  #291
cKHyper's Avatar
The WDP Noob
I have some blinker problems
it doesn't flash properly when the car starts cold...
it starts flashing properly after a few blinks
Old May 25, 2008 | 12:45 AM
  #292
fiore8072's Avatar
im interested in doing this to my car. cleared/painted headlights
Old May 26, 2008 | 08:51 PM
  #293
cKHyper's Avatar
The WDP Noob
I have changed my details if u don't mind doing that for me JnC
1. ImaGRaNTes - cleared / blacked out w/ trade in program DONE
2. OUT
3. CrazyFresh - cleared / blacked out w/ trade in programDONE
4. KimboBread- 08 cleared with trade in. DONE
5. TSXINITY- cleared w/trade in program (2007 model)HOLD
6. jokerunm - cleared/blacked out (type-s) DONE
7. lembowski - cleared / Anthracite painted w/ trade in program DONE
8. lileasy123 -Cleared/blacked out 07 (type-s)
9. OUT
10. slimboogie-- Colormatched SSM DONE
11. as2222- BACK IN cleared/ blacked out (07 type-s) w/ trade in
12. Acurachic05 - cleared/painted ABP I will provide paint can and also the halos
13. OUT
14. phenomengan - cleared/blacked out w/ trade in (2004)
15. bent09- cleared / silver painted ASM with trade in (2006)
16. Aztec209- Clear with trade in 2004
17. dumamei- cleared/blacked out w/ trade in (2008)
18. MAC TL-- 2004 TL
19. nY mALu 86 - clear/blacked out except for chrome reflector with trade in (2004)
20. aascsm - cleared/blacked out (2004)
21. cKHyper - cleared/blacked out except for the chrome reflector keep the DRL ring
22. NighthawkA-spec- Cleared/Blacked out w/gloss finish w/trade program (2004)
23. bTwix - clear/blacked out except for chrome reflector with trade in (2004)
24. Rooki- Cleared/blacked out with chrome reflector DONE
25. TL1999
Old May 27, 2008 | 06:14 PM
  #294
markk1661's Avatar
Am I to late for this group buy?
I would like cleared/blacked out w/ trade in (2005)
Old May 30, 2008 | 01:14 AM
  #295
bTwix's Avatar
Updated my info
2. OUT
9. OUT
13. OUT
23. bTwix - clear/color matched AM except for chrome reflector and carbon fiber inserts with trade in (2004)
25. TL1999
Old May 30, 2008 | 09:16 PM
  #296
phatbastard's Avatar
I would also like cleared headlights for a 06 TL, message me if i can still get on the list, thanx.
Old May 30, 2008 | 10:22 PM
  #297
TSXinity's Avatar
#TeamBoosted
Ok I am ready . Everything came in the mail. JNC please check your pm and send me email/address for payment and halos.
Old Jun 2, 2008 | 09:03 AM
  #298
JnC's Avatar
JnC
Former Sponsor
Waiting on the headlights, I'll get in touch with you once they do .
Old Jun 2, 2008 | 09:24 AM
  #299
JnC's Avatar
JnC
Former Sponsor
Phenomengan's headlights are DONE
While I wait for others paint etc to come in I thought I should get Phenomengan's headlights out of the way.
2. OUT
3. CrazyFresh - cleared / blacked out w/ trade in program DONE
5. TSXINITY- cleared w/trade in program (2007 model) HOLD
9. OUT
13. OUT
14. phenomengan - cleared/blacked out w/ trade in (2004) DONE
25. TL1999
Old Jun 2, 2008 | 10:42 AM
  #300
TSXinity's Avatar
#TeamBoosted
Should I be sending you the halos rite now since you are waiting so that way you don't have to wait on me again to send it (halos) in?
Old Jun 2, 2008 | 02:31 PM
  #301
fiore8072's Avatar
2. OUT
9. OUT
13. OUT
25. TL1999
26. fiore8072- Cleared/Anthracite painted w/ trade in program (2004)
Old Jun 3, 2008 | 03:58 PM
  #302
NighthawkA-Spec's Avatar
A-SpecBlackout
i cant wait for these! JNC are u able to supply/install halos as well?
Old Jun 3, 2008 | 04:16 PM
  #303
JnC's Avatar
JnC
Former Sponsor
Fiore, sorry bud not adding any more names to the GB at the moment.
Nighthawk, I cant provide them but if you do provide them then I'll install them free of charge.
Old Jun 4, 2008 | 11:52 AM
  #304
slimboogie's Avatar
JnC,
Just got the headlights in the mail yesterday and I will be installing them today. I'll have my headlights back in the box and out the door either this afternoon or first thing tomorrow!
Old Jun 4, 2008 | 12:56 PM
  #305
o4Komodo's Avatar
Rev High; Drive Happy
This is still going on?
Would/can you do Blacked out o4 headlights with smoked diffusers [while keeping the silver lining] and ZKW lens?
Looking for possibility of the swapping method... if you are willing to ship to Canada.
Old Jun 4, 2008 | 12:57 PM
  #306
o4Komodo's Avatar
Nevermind just read your most recent post. Hahah. I fail.
Old Jun 5, 2008 | 06:02 PM
  #307
slimboogie's Avatar
JnC,
Finished up the install last night and they look great Just shipped out my headlights about 2 hrs ago and should be about 5 days.
My other baby!
Old Jun 5, 2008 | 07:02 PM
  #308
jingy08's Avatar
when do you estimate you will be taking new customers JnC? Or will you ever?
Old Jun 6, 2008 | 06:03 AM
  #309
JnC's Avatar
JnC
Former Sponsor
Slim the headlights look great, I wasnt digging the bright SSM on the headlights but I stand corrected after looking at the headlights installed on the car
Jingy, as for now this GB is closed for any further entries once its completed I'll decide if I want to become an official vendor or not.
Old Jun 6, 2008 | 10:21 AM
  #310
lembowski's Avatar
Trucki!!
Wow slim those look great! If I haden't done my hood I would have had done the SSM match. I look at the metal flake in my lights and say wow everytime I walk by!
If any of you guys are out there debating between the stock blacking out or a color match definately do the color match. From the pictures it definately looks like the aerosol match colors lay down smoother and have a nicer texture. And if you don't want to match and have that black color order the NBP and have that metallic color flow on the car! Its definately a good $30 extra investment in your lights!
Old Jun 6, 2008 | 10:30 AM
  #311
JnC's Avatar
JnC
Former Sponsor
I am getting RRP for my car as well .
Old Jun 6, 2008 | 11:00 AM
  #312
slimboogie's Avatar
thanks lembowski,
I got the lights in just in time for the atlanta meet
Can't really see in the pictures but the chrome portion of the light still has a chrome but silver painted look to it. Pure hotness. Thanks JnC.
Definitely do the color matched.... well worth it!
Old Jun 6, 2008 | 11:08 AM
  #313
bent09's Avatar
horny =
I can't see pics
Hey JnC would you add Halo's as well?
Old Jun 6, 2008 | 11:10 AM
  #314
lembowski's Avatar
Trucki!!
Originally Posted by bent09
I can't see pics
he will do Halo's you just have to send them to him......install is free
Old Jun 6, 2008 | 11:16 AM
  #315
JnC's Avatar
JnC
Former Sponsor
I can't see pics
As lembowski said, just send them over and I'll install them free of charge.
Also I am not sure if you read my note a couple of pages ago about trade in program for 06 headlights, as of right now I dont have a pair so you would have to send yours in
Old Jun 6, 2008 | 11:54 AM
  #316
FiveLiterCheater's Avatar
If you're still doing this, i'd be interested in a 05' black out Let me know
Old Jun 6, 2008 | 12:54 PM
  #317
bent09's Avatar
horny =
No problem. I will pm you.
Old Jun 6, 2008 | 07:36 PM
  #318
Hotboyzz69's Avatar
3rd Gear
Hi JnC - I live right here in Boston. I'd like to link up with you. I hope you open up the GB soon.
Old Jun 7, 2008 | 05:04 AM
  #319
JnC's Avatar
JnC
Former Sponsor
Going to hear back from Robb soon on vendor status, if all goes well I might become vendor prior to the group buy completion
Old Jun 7, 2008 | 08:05 AM
  #320
fokkerfitch83's Avatar
Registered Nutsack
If all goes well count me in on this too
