Clear headlight....help guys
Old Oct 10, 2008 | 05:55 PM
jameshtx's Avatar
7th Gear
Can anyone tell me how to clear my headlights? Thanks
Old Oct 10, 2008 | 06:36 PM
voigt's Avatar
Here is the thread I used to do mine
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-blacked-cleared-headlights-3g-garage-g046-589746/
Here is my thread
https://acurazine.com/forums/3g-tl-2004-2008-93/another-headlight-black-out-journal-w-partial-orange-reflector-643387/
Old Oct 10, 2008 | 06:40 PM
xen-cuts's Avatar
ROFLCOPTER!
what does the baking do? and what happens if I don't bake them?
Old Oct 10, 2008 | 06:44 PM
usc's Avatar
usc
baking (heating them up) softens the adhesive that seals/glues the pieces together. you'll want to get some kind of a heat gun if you don't bake them, but baking them would be infinitely easier as the entire seal is softened instead of one small section at a time.
Old Oct 10, 2008 | 09:17 PM
Trew's Avatar
You will regret using a heatgun over sticking your headlights in the oven. The oven heats the entire seal evenly, where as the heatgun will only apply heat to the spot you're pointing at. By the time you get all the way around, the first spot has already cooled.
Old Oct 10, 2008 | 11:28 PM
mattpete's Avatar
I used a heat gun and found it to be easier than the oven. I used an oven for a projector conversion I did on my old Legend. They both work well; just a personal preference. If you use the heat gun just be patient and run the heat gun all the way around the seam until it softens, then just pry away with a screwdriver. Here is my thread on my black out and zkw swap.
https://acurazine.com/forums/3g-tl-2004-2008-93/headlight-clearing-686453/
Good Luck.
Old Oct 11, 2008 | 12:22 AM
xen-cuts's Avatar
ROFLCOPTER!
Thanks so much!
Old Oct 12, 2008 | 11:30 AM
jameshtx's Avatar
7th Gear
anybody in the houston area does the clear heads? it sounds pretty easy to do it but if i mess up i dont feel like buyin a new unit...yall feel me...
mada51589
Jan 9, 2025 04:40 PM
ripit
Feb 26, 2016 08:14 PM
JByron
Jan 8, 2016 09:49 PM
jmoney2001
Sep 11, 2015 12:07 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
