Cleaning Navi Screen
Any suggestions on the best way to keep the Navi screen clean without scratching? I have been using tap water and tissue but was thinking of buying some wipes I could leave in the car.
I would read the nav manual, pg 9 says to clean the screen with a soft, damp cloth. You may use a MILD cleaner intended for eyeglasses or computer screens. Harsher chemicals may damage the screen.
I once used alcohol to clean a plastic part on a stereo system and it turned white. alcohol is not mild, so be careful!
Also, make sure the car is off when you do this.
Originally posted by 00TLOwner
Buy some Isopropyl alcohol pads from your local drug store and use them to wipe. The alcohol evaporates so there is no chance of water damage to the electronics.
I bought some computer cleaning wipes from office depot.
They come in this lil cannister.. they are small and in fact have just enough wetness to use once.
They do not streak also.. they come with a little shammy cloth to wipe afterwards.
That is what I use.
I am using the joystick more and mmore however now that much of the inititial programming is done.
Mike
That is what I use.
Mike
That is what I was thinking of using. Just a little paranoid about causing a sratch on that surface. I haven't used the joystick a whole lot. But I am getting to where I use the voice options all the time! That is so cool, even if it thinks "Find nearest american restaurant" means "set temperature 72 degrees"
Get a microfiber cleaning cloth. It will keep the screen clean without cleaning solutions. If you use something else , it should just be a damp cloth. Do NOT spray ANYTHING directly on the screen, spray it on the cloth first.
i use eletrostatic dry cloths like Swiffers and Grab-Its. Just be sure to use the dry ones. They pick up dust like nothing else and are soft enough to rub off fingerprints. I also use them on the dash and doors. They're great.
When I saw the little polishing cloth with my T616, a light went off in my head and I now use it to clean the nav screen in our TSX. My MDX came with a blue cleaning cloth, so now I have to scam one for the TL when it gets here.
Originally posted by danno
Also if you were given a polishing cloth for your cellphone face(my T616) that works pretty good and its small and in its little packet
Originally posted by Jss1
Thanks I just got my T616. I was wondering what that was.
I second the recommendation for the LensCrafters cleaning cloth: it works great and won't scratch the screen.
Originally posted by rick955i
Sunglass hut also carries the microfiber cleaning clothes....if you dare to brave the malls this weekend!
Do you use the fluid as well??
Originally posted by MikeRadio
I saw trhis.. it comes in a little case with some fluid and the rag.
4drviper
Apr 23, 2025 07:13 PM
rboller
Sep 23, 2015 02:49 PM
