Changing out HID
Changing out HID
So yesterday my passanger side 4300K stock HID bulb turned pink... i was pretty fuckin mad but whever it happens.... my question is though how hard is it to change out the bulbs... im assuming most to all of you guys who upgraded to 6000k ect. changed them urself... ive searched and i just want to hear it from you guys now cause the last thread i found was from 2005... is there any tips or tricks to doing it quick because im am so pressed for time this weekend thanks... and what exactly is the process do i have to take off the bumper?
iScrape going into
First off when you get the replacement bulbs, or if you have someone put them in for you. WEAR LATEX GLOVES, do not risk getting your finger oils on the bulbs it will destroy them. Passanger side is a ton lot easier cause not alot of stuff in the way, the driver side is alittle trickier, I know alot of people have removed the inside wheel well fender lining and went in through their to change the driver side bulb out.
The passanger side you can do through the engine bay but the the driver side is alittle trickier, you can do it from above but will probably need to remove the battery to access it.
It's really not to bad maybe 20 minute job, there is a DIY in the 3G Garage that someone wrote how to do it So I would suggest looking in there.
Photographer
both sides i did through the engine bay. as you stated the drivers side you do have to remove the battery though.
it's me, Alan Rickman.
I tried the easy method and after about an hour gave up... the reason I had so much trouble is that the torx screw that holds the cover in place is actually a security torx screw.
Make sure you disconnect all wires connecting to the headlights and the ignitor/regulator; the amount of voltage that thing generates can kill you
Photographer
Former Sponsor
Usage, you'll be seeing more and more of this soon with 04-05 headlights, then in a couple of years the ballasts would start going bad, I am already seeing this with 02-03 TLs as their ballasts are going out without any evident reason.
OP, spend some dollars and get a fresh pair of bulbs for both headlights to make sure the color is same from both.
ThAnks guys the bulbs I got from excelerate I'm assuming are good and if I disconnect the battery I don't have to be worried about getting electricuted??? Also how the he'll do I get that tors screw out do I need special tool??
idk maybe this will help u guys determine if its the bulb or the ignightor... when i turn the lights on its starts out as blue then it gradually turns to pink
dude, take off the bumper..it makes the change so much easier. I tried the simple way first and it was just a PITA. I ended up removing the bumper and then taking out the headlights which is not that hard. Bumper removal will take you 30 minutes at most if its your first time.. Check out SanDiegoDrive's sweet DIY video https://acurazine.com/forums/3g-tl-2004-2008-93/diy-video-updated-removing-front-bumper-3g-garage-e-080-a-628363/
The headlight change after that won't take you that long either, maybe about another 30 minutes. Take a look at this thread for the scans https://acurazine.com/forums/3g-tl-2004-2008-93/headlight-front-bumper-inner-fender-w-wash-tank-hid-bulb-scans-garage-e-001-g-001-a-587181/
In all it should take at most about 1.5 hours. Trust me, its not worth the frustration to change the bulbs without removing the bumper.
GL.
GL.
Mine lit up fine, then about 20 seconds later turned pink.. after a day or two it started arcing like a strobe light everytime i turned my lights on for about 2-3 minutes, then it finally shut off. The HID system goes through 2 phases I believe, first is initial burn then it maintains the voltage to keep the xenon gas ignited. Since my regulator was messed up it was starting/then dropping/starting/dropping etc etc.
Either way get new bulbs and replace them both!
i hope you know the stock bulbs ARE covered in you orginal bumper to bumper warrenty, if you still have it, acura just switched out mine FOR FREE LAST WEEK, mine also burned out!!
i called to ask thinking there was no way they were covered, but to my amazement THEY WERE!!!!
nice so juust an update i changed the bulb and thankfully it was the bulb and not the ballast and it took me an hour and a half to take the bumper off take the light out and just swap both bulbs thanks for all your help guys
BoricuaTL
04-08-2016 01:08 PM
pistacio
09-26-2015 09:45 AM
