Changing fuel filter.
has anyone done this yet??? I know that acura states that you shouldnt do this for 100k but I am adding the charger and i wanted to know if any one has the dealer book pages on this. If you can please help me out. thanks in advance
I cant imagine they would be so stupid to put the fuel filter in the gas tank.
The pumps all have inlet screens, but i have never seen a fuel filter inside a gas tank.
Look under the car, trace the lines from the fuel pump to the front of the car.
There is typicly a big filter in line under the car someplace.
Since fuel always flows from the pump, to the fuel rail, and most returns to the tank, a lot of fuel circulates through the filter. Very little actualy gets used by the injectors and most returns to the gas tank. Only at full throttle, high rpm's, with a cold engine would get close to using most of the fuel flow to the fuel rail.
Most modern fuel filters are quite large to handle all that flow, the VW filter was good for 100,000 miles (they said) and was about 5 by 3 inches in size.....
Brett
Brett
The filter is absolutely inside the fuel tank. The 2004 Service Manual, page 11-256, says:
The fuel filter should be replaced whenever the fuel pressure drops below the specified value (see page 11-247), after making sure that the fuel pump and the fuel pressure regulator are ok.
Page 11-247: The pressure should be 330-380 kPa (3.4-3.9 kgf/cm(sq), 48-55 psi)
I haven't found anything that says anything on replacing the fuel filter on a specified mileage basis.
Originally Posted by Brettg
I guess that ties in with the oh so easy to replace cabin air filter...
Brett
Brett
No, this one is easier to replace. There is an access hole in the trunk floor, so you don't have to pull the tank. Just remove the trunk floor, remove the cover, and then use the special tool (the only tricky part for the do-it-yourselfer) to remove the collar and then the fuel pump lifts right out.
Same as the Passat. And the fuel filter is in with the pump?
Brett
Brett
The filter is #5, and the fuel pump module assy is #2.
Click here for the Parts List
Number 5 does not look anything like a filter to me, more like plumbing between the pump and the bung. if there is a filter in there, its just a screen, as there looks to be nothing in there big enough to be a real paper fuel filter that is going to hold 100,000 miles worth of dirt.
Brett
Brett
Brett
Brett
You're entitled to your opinion, and you stick with the 100,000 mile figure, but at the price listed it is probably more than a screen, and if Acura thought it should be serviced regularly they probably would have told us.
This is the only fuel filter listed in the service manual index, and the picture of the fuel lines doesn't show a filter either.
Thanks for the info.
Some sort of crazy setup, I guess the filter is the round thing below the bung top, quite small for something that is placed inside the gas tank.
I wonder why they did it that way.....
Brett
Brett
NBP_BALLER
09-23-2015 08:18 PM
