Changed to Amsoil ATF
Old Jun 30, 2006 | 02:11 PM
againstallodds1's Avatar
Import and Domestic owner
I just changed my tranny fluid from Redline to Amsoil ATF. First I noticed a big difference in smoother shifting. But I also noticed that the low end trq is not there. Michael Wan will hopefully chime in on this one. So smoother shifts Bad low end trq Before when I would tap the pedal from a stop it would put me back in the seat. Now when I do it, its just too smooth. No trq.
Old Jun 30, 2006 | 03:44 PM
Jrbn2g04AcuraTL's Avatar
Man, I dont know bout the "No torque"....... I want some low end torque
Please uppdate us if it the car react differently after a few miles.... Thanks
Old Jun 30, 2006 | 04:02 PM
SodaLuvr's Avatar
Did you just do one drain/fill with Amsoil?
The main question here is whether the transmission behavior you're currently experiencing was also experienced with Honda Z1. In other words, when your first bought the car, did the transmission function this way?
You can try resetting the TCM by disconnecting the battery cables, and having it relearn your shifts.
Old Jun 30, 2006 | 04:56 PM
Must of been the computer, car is back to normal, with smooth shifts. Got a little scared at first, but torque is back.
Old Jun 30, 2006 | 04:59 PM
SodaLuvr's Avatar
Yep, that's sometimes normal. The computer takes time to "adjust" to the new fluid. If you reset the TCM, that speeds up the process.
Old Jun 30, 2006 | 05:31 PM
I did a semi flush. I drained and filled 3 quarts. Drove around for 10min, and drained and filled once more. I am resetting the transmission control unit now.
Old Jul 1, 2006 | 02:02 AM
Ok, I spoked to my mechanic about the lose of torque and he couldn't believe the loss torque... Too bad i ordered the redline from comptech earlier.. wish i can cancel it...
Old Jul 1, 2006 | 08:01 AM
cristphoto's Avatar
Question
Does this Amzoil ATF meet the Honda spec for ATF? I wasn't aware of any synthetic ATF available that met the Honda spec? Please double check. Thanks.
Old Jul 1, 2006 | 09:17 AM
pimpin-tl's Avatar
No low end TQ? If its slipping you will loose power. This is why you don't mess with the Honda ATF. I sell Amsoil as a dealer, but will not mess with the tranny on this car.
Old Jul 1, 2006 | 09:46 AM
The torque is not gone anymore. The computer just relearned my shifts. Everything is good now. I like it.
Meets honda Z1 specs.
Old Jul 1, 2006 | 10:47 AM
pimpin-tl's Avatar
http://www.amsoil.com/storefront/atf.aspx
Correct it does meet Z1 spec.
Old Jul 1, 2006 | 10:54 AM
ACCURATEin's Avatar
tehLEGOman
I've been running this fluid for 22,000 miles and no problems.
Old Jul 1, 2006 | 12:04 PM
leedogg's Avatar
RAR
How many quarts does the TL require?
Old Jul 1, 2006 | 12:59 PM
BustedJack's Avatar
The Boss
If you read the Amsoil ATF specs, it meets and exceeds all the requirements of a Honda ATF Z1 specs. However, if you compare the charts and the numbers between Redline ATF vs Amsoil ATF. Redline products EXCEEDS Amsoil....... but then again... those are just numbers. Personal experience counts and seems like eric has been running his car in Amsoil ATF for 22k and no problems. Paul recently shifted to Amsoil and seem to have better shifting. Meanwhile I have Redline and had hard shift before, but since lubeguard, it's been fine.
I will change to Amsoil upon my next tranny fluid change.
Thanks for the heads up Paul
vpasla1
Sep 17, 2016 07:24 PM
nanos
Nov 12, 2015 08:41 PM
Skirmich
Sep 15, 2015 06:41 PM
mc1114
Sep 11, 2015 05:50 PM
Aleax
Sep 11, 2015 11:31 AM
