center console noises
Old Jan 12, 2007 | 11:49 AM
ebs312's Avatar
I know about the rattles that ppl hear, but the noises I hear on my car come mostly from the center console. Especially near the shift knob and center storage area. It sounds like plastic creeking. It only happens in the winter months.
Anyone else have this problem and if so, is there anyway to fix it?
I tried doing a search, but found no results. Thanks in advance.
Old Jan 12, 2007 | 11:54 AM
simonsez's Avatar
A-SPEC
i have the same prob too...
i give it a smack on the center plastic piece by the shift knob then the squeeking goes away!
Old Jan 12, 2007 | 02:50 PM
lusid's Avatar
FTW
I think you can tighten the screws inside the console... There was a picture thread that i remember seeing but dont recall the name of the thread.
Old Jan 12, 2007 | 07:04 PM
csmeance's Avatar
it is the satin look pieses on the shifter area, push down on it and it stops
Old Jan 12, 2007 | 10:02 PM
Kracker's Avatar
05 TL
Or wedge something under it... Piece of paper.. Just to see if thats the problem.
Old Jan 12, 2007 | 10:06 PM
Will Y.'s Avatar
Registered but harmless
Originally Posted by ebs312
...the noises I hear on my car come mostly from the center console. Especially near the shift knob and center storage area. It sounds like plastic creeking....
Csmeance is likely correct- sounds like it's the shifter trim plate. There are several threads, probably findable with a search of "creak" or "squeek," "console" and "shifter."
The fix was a little bit of teflon tape under the shifter trim plate; the 3G garage may have a guide to this fix: https://acurazine.com/forums/showthread.php?t=84834
Old Jan 13, 2007 | 05:52 PM
sftroy's Avatar
The dealer will fix this with foam tape. This is a common prob. and they should know how to correct it.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
vpasla1
Sep 17, 2016 07:24 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
