Is this car worth the money?
#41
well isn't that just silly ? i wouldnt just decide to remove my emergency cuz im too lazy to figure out how to do it properly. with that being said, i will most likely leave the stock caliper alone for now. maybe one day the bug will bite me and i will look into doing this the proper way.
#42
I believe the Brembo calipers from the Evo are the exact same model number as the units on the front of the 6MT TL (as well as the TL Type-S); assuming that's the case, there isn't enough room between the larger rear hat (larger because the parking brake shoes live inside the hat) and the inner surface of the wheel rim.
#43
So when are you buying it
#45
NOICE
#51
i will post a separate thread soon with more day time pictures.
but the car is super clean inside and outside. no leaks anywhere, no rust. suspension is solid. owner #2 removed the resonator and the third cat and had some RS mufflers installed and it actually sounds nice and not raspy at all. i think i may add a resonator back to tone it down a notch. ill decide after i get it on the road soon.
#52
If you'd like, you can just add it to this thread, and I can rename the thread and move it into the Photography subforum so you have a timeline of your car's journey all in one place
#54
thanks man, im very excited about the new journey with this car. i plan on keeping it for a very long time.
#56
i found a couple for that low but they needed a ton of work, i dont mind the mechanical work much but a body that is in a rough shape is nothing i want to deal with.
#57
OP I wouldn't worry too much on the car you bought since the interior is in good condition, whoever had it seem they really take a good care.
#58
few small things need to be fixed. like the climate control light bulbs. plastic cover under the steering column is not properly secured. need to clean the short ram air filter. that is all i spotted last night.
