Car accident
#81
6spd FTW
My friend's base TL had tight steering for about a week after they replaced the trans. I do know that the type-S rack takes a bit more steering effort compared to a normal car, so you may be feeling that. But definitely bring it back.
#82
You might have a point about the rental that I been driving for the past 2 months. I complained to the guy at the shop about the tightness. He said the handling is better than before and he didn't see any problem in the tight steering wheel.
Anyway, here are the spec. I hope you can see them. I use my cell phone to take the pics.
![](https://acurazine.com/forums/members/myacura07-213789-albums-car-accident-7250-picture-bef-40259.jpg)
![](https://acurazine.com/forums/members/myacura07-213789-albums-car-accident-7250-picture-aft-40260.jpg)
#83
B A N N E D
i can read the numbers some, but enough though
personally i would want a little more castor up front,but not really adjustable though, so not much you can do about it easily (i like it on the higher side of the specs, so you do not have to run as much negetive camber, to get the tire flat in turns), BUT it is basically even though, so can't complain about that too much though (and maybe even a little bit more on the passenger side (or is it the driver side
tomato: can't remember right now) to compensate for road crown some
also maybe the camber COULD be a little more even too, but then again a driver hops into the car, and that will probably basically even right out though
but kind looking at those numbers though, i bet you the car drifts ever so SLIGHTLY to the right? (or is it the left
(btw that steer ahead is good to know, but can easily be change though, if the steering wheel is not levaled EXACTLY as the same as the before measurement)
then the back, can't complain about that camber within 0.1 of each other
same thing with the toe (and that thrust angle
also i was thinking of more in "detail" numbers, but you probably don't have them though on the printout, since you did take a picture of it LOL
![Rant](https://acurazine.com/forums/images/smilies/rant.gif)
#87
IMO find a good shop that does quality work. Ask local performance shops and such for a good shop and go there and see some of the work they do.
#88
#90
#91
I was told the reason for the mismatch wheels was Japan no longer make them anymore. Another company in the U.S took over and they don't use lead in the paint like Japan does which explain the different shade of color. As for the different color in the navigation screen, I brought the car to the Acura dealership to inspect and they told me I need a new unit. Apparently the one the body shop put in was defective. They wanted to charge $3500 for the unit and $400 for the disk. The body shop inform me they will only pay for the diagnosis fee of $123 charged by the dealer. And they will reorder the unit instead of having the dealer fix it. Here is the kicker, whatever the dealer did after I got my car back, the screen is back to normal. Not sure if it has to do with them reconnecting everything correctly or the unit will die again. I don't know who to trust anymore.
#92
B A N N E D
I was told the reason for the mismatch wheels was Japan no longer make them anymore.Another company in the U.S took over and they don't use lead in the paint like Japan does which explain the different shade of color. As for the different color in the navigation screen, I brought the car to the Acura dealership to inspect and they told me I need a new unit. Apparently the one the body shop put in was defective. They wanted to charge $3500 for the unit and $400 for the disk. The body shop inform me they will only pay for the diagnosis fee of $123 charged by the dealer. And they will reorder the unit instead of having the dealer fix it. Here is the kicker, whatever the dealer did after I got my car back, the screen is back to normal. Not sure if it has to do with them reconnecting everything correctly or the unit will die again. I don't know who to trust anymore.
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
, and anyways it is more then likely a ENKEI wheel, still a Japanese company (or should be at least more then likely)
but more then likely they will be reconditioned wheels, which means repainted, so the reason for the crappy paint match; i would still want them repainted to match better though)
and as far as the navi, they may have gone into the diagnostic menu, and recalibrated there, compared to what you might have been able to do at home
and personally i would trust the dealer more so in this situation
#93
#95
Your Friendly Canadian
Received 1,485 Likes
3 accidents and 3 different repair shops later, I have yet to find a decent a repair shop even with extensive research. My car either came back with overspray, non matching paint or poor alignment. Insurance would always recommend that I not take it to the dealer because they would not offer lifetime on the paint and I "would" get a better deal through local repair shops. Actually, all I got was headaches. Around that time my friend also had had an accident and took his car to the dealer.....and things were done right the first time.
SO i guess I'm speaking from personal experience, but local repair shops didn't yield great results. -2002 Acura TL RIP
It's VERY hard to find a reputable repair shop, but they do exist.
#97
Whenever insurance is paying for any work, I would just take the car to one of the 2 local Lexus dealers that have their own Lexus Certified Collision Centers. Man do they do good work. After having so many fender benders, I've learned not to sign anything until I've been through every little thing inside and out of the car.
#98
#100
#101
B A N N E D
so does the local honda dealer here too, it's even in the same building too (but in there own little area there)
had to take my acura there once for an insurance quote,
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
#106
^ sucks with the mismatched wheels but atleast ur nav is working properly now, like everyone said i think your best bet would be to put the two mismatched on one side of the car, that way u will hardly notice
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
