Caliper painting help
Old 10-01-2012, 05:30 PM
  #41
-Double Dee-'s Avatar
Originally Posted by KJ TL-S
Looks awesome Double Dee. I'm assuming you used the brush on kit? Did you use the supplied brushes, or your own? Some reviews I've seen read say that the brushes are crappy and you end up pulling bristles out as you paint.
Thanks! I used the supplied brush, I think I only had one bristle fall out. Maybe I was just lucky cause the brush they supply defiantly isn't anything good, but it worked for me! Maybe just to be safe pick up an extra brush just in case the supplied one falls apart on you. And remember that you only have 3hrs? before the paint hardens! Just follow the instructions and it will turn out great!
Old 10-01-2012, 09:47 PM
  #42
danl23880's Avatar
Justnspace or sharksbreath are the ones I purchased the same on your car? I'm almost leaning towards the smaller calliper cover but then again I recall in one of your threads you originally bought the small ones and in order to make it fit you had to order the bigger 9 inch ones that I got. Am I wrong?
Old 10-01-2012, 11:23 PM
  #43
sockr1's Avatar
Received 1,158 Likes on 909 Posts
Originally Posted by danl23880
^^^ please post. Thanks sockr1
here are my brush painted calipers with g2 white paint, brembo stickers are from ebay. i asked the seller for 4" wide x 1.05" tall since i researched and found that was a great size for the front calipers (one thread discussed sizes in detail). again, may be a little messy but i didn't want to mess with taking them apart, good enough for me (for now)
brembo decal link: http://cgi.ebay.com/ws/eBayISAPI.dll...r=590061926499
rear:
front:
i put an order in for some chromium black xxr 530 wheels, so hopefully they show more of the caliper! let me know if you have any questions
KJ TL-S (10-29-2012)
Old 10-02-2012, 12:10 AM
  #44
danl23880's Avatar
Very nice looks like the decal fits much better that size. No clear coat for sticker?
Old 10-02-2012, 08:12 AM
  #45
sockr1's Avatar
yea i liked the size i got, it wasn't so big that it overlapped on the sloping face of the brembos.
no clear coat is needed, you paint wait an hour or two, then put the sticker on. the sticker is a great touch and you can get them in any color
Old 10-02-2012, 08:16 AM
  #46
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
this thread
GO PAINT YOUR CALIPERS, DAN! YOU COULD HAVE PAINTED 10 CARS BY NOW!
Old 10-02-2012, 10:20 AM
  #47
danl23880's Avatar
Lol I no I no.
Waiting on paint so am stuck.
Old 10-02-2012, 01:30 PM
  #48
stavebomb's Avatar
Awesome posts. Is there a consensus whether to use the brush paint or spray?
Old 10-02-2012, 01:32 PM
  #49
BANNED
personal preference i suppose.
i love aerosal spray cans tho...i feel like its easier to get even coats with them.
Old 10-02-2012, 05:37 PM
  #50
danl23880's Avatar
I no this is annoying but today I did some prep work and sanded calipers and stuff so when paint comes this Friday all I need to do is Paint them. For the rears I am trying to figure how to install these brembo covers and man theses 9 inch ones look way big. I might be sending back for the smaller covers.
Old 10-02-2012, 06:45 PM
  #51
Chapter Leader (Midwest Region)
McCollins23's Avatar
If you are gonna use the G2 kit, I would suggest getting one of those Preval sprayers at HD or Lowes to paint the brakes. Mix the hardener with the paint and then load it in the gun. And there is no need for a clear coat over the stickers, mine has been on for 5 months with no problems.
Old 10-02-2012, 07:06 PM
  #52
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Those look excellent Sockr.
Old 10-02-2012, 07:38 PM
  #53
sockr1's Avatar
thanks! now i just need to update my progress thread...
Old 10-02-2012, 07:48 PM
  #54
splew's Avatar
^you're right. Yellow red are ricer colors!!!
Yes clearly....
Check out these rice cookers.
Old 10-02-2012, 07:53 PM
  #55
Received 16,260 Likes on 11,971 Posts
Originally Posted by splew
Yes clearly....
clearly, we're talking about the Brembo TL's.
clearly.
Old 10-10-2012, 05:30 PM
  #56
danl23880's Avatar
Can someone help me out ASAP. Installing my pads after paint job. Pictures soon. However in photo above from double dee he has the pad clip on the top half of the rotor. I have mine on the top Only 1 pad for each side has this clip and it looks like it serves no purpose earthier way. Someone please let me know. Thanks.
Old 10-10-2012, 07:09 PM
  #57
For $7.00, I ordered a set. I need to re-do my Brembos.
Old 10-10-2012, 08:01 PM
  #58
danl23880's Avatar
http://i873.photobucket.com/albums/a...0E20F827F6.jpg
Look in this photo where my finger is pointing. This is what I am talking about (the clip on the 1 calliper for each front brake? Does it matter if it is on the upper half or lower half of the rotor. Obviously mine is on the lower. Please let me know. Honestly like I said that clip looks like it does nothing eathier way? Let me know
Old 10-10-2012, 08:17 PM
  #59
geekybiker's Avatar
You're looking at the pad wear indicator. Can't say 100% but that might just vary by pad maker. The only way you could flip it is installing your pad backwards. Make sure your backing is facing the caliper.
Old 10-10-2012, 08:35 PM
  #60
danl23880's Avatar
Thanks for the reply but I don't understand? ......
Old 10-11-2012, 12:21 AM
  #61
danl23880's Avatar
Anyone. Hoping I am able to drive it. They don't serve a purpose just to show wear on pads and when time to replace correct.
Old 10-11-2012, 10:39 AM
  #62
geekybiker's Avatar
Your brake pad has a metal back plate (the part the pins go through on top) and the actual pad material. The only way you could change what side of the caliper the wear indicator is on is by installing the pad rotated 180 degrees. Just make sure the metal backing is towards the caliper and not the rotor. If that's the case, I'd chalk it up to manufacturer differences.
Yes.
Old 10-13-2012, 04:03 AM
  #63
AbyssBlue2005's Avatar
Just painted mine silver. They look great and don't slow much dirt..
Old 10-13-2012, 08:35 AM
  #64
Kakarotx's Avatar
clearly.
Sick!
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
polish_pat
09-30-2015 12:22 PM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: Caliper painting help
