CAI for 79 bucks?
Old 03-30-2004, 04:44 PM
rynpamn21's Avatar
Question CAI for 79 bucks?
Was just searching ebay for some stuff and i saw this....http://cgi.ebay.com/ebaymotors/ws/eB...tem=2470033467...
description read as...
THIS CP COLD AIR INTAKE SYSTEM HELPS TO DRAW MORE AND COLDER AIR TO YOUR ENGINE THAN YOUR STOCK AIR BOX SETUP AND GIVE YOU APPROXIMATELY 10-15 HORSEPOWER INCREASE. YOUR RESULTS MAY VARY, BUT THE SOUND WILL DEFINITELY BE MORE INTENSE. THIS KIT COMES WITH INTAKE PIPE, HIGH FLOW WASHABLE & REUSABLE STAINLESS STEEL AIR FILTER, HIGH PRESSURE SILICON HOSE AND MOUNTING ACCESSORIES. MADE OF MANDREL BEND ALUMINUM PIPE AND GIVEN A CHROME POLISHED FINISH. EASY TO INSTALL WITH SIMPLE TOOLS. THIS AIR INTAKE IS ALSO C.A.R.B. APPROVED LEGALLY THROUGHOUT ALL 50 STATES AND 100% BRAND NEW. PLEASE CHECK THE DYNO TEST CHART BELOW:
so i was just wondering what you guys think about this? I was looking at what other name brand cai's had and they practically had the same stuff in it. There's also another w/ a K&n filter for 20 bucks more.....
Old 03-30-2004, 04:45 PM
cM3go's Avatar
your 04 TL already has a cold air intake system
Old 03-30-2004, 04:47 PM
TLover's Avatar
I think it's a typo. It says it fits years 2001-04. The 2004 is different.
Old 03-30-2004, 04:49 PM
rynpamn21's Avatar
Question
i know but it's kinda restricted right? all i want to know is if it will work just as good as the ones made by INJEN. BTW,they are selling the injen cai on ebay for 230 something ...check it out here http://cgi.ebay.com/ebaymotors/ws/eB...tem=2469403617
Old 03-30-2004, 04:50 PM
rynpamn21's Avatar
i emailed the seller and according to him it will fit the 2004.
Old 03-30-2004, 05:14 PM
Team Nghthwk Whipping Boy
WickedWiz's Avatar
Hmmmm...if it sounds too good to be true, than it's too good to be true. :think:
Old 03-30-2004, 05:15 PM
What's a TL?
VTEC=happiness's Avatar
First off, I wouldn't trust some generic brand for a CAI (I would fear noise problems as well as performance issues). Also, the one pictured does not look like the Injen one I installed (shape/size wise). Finally, there is no way that there is a CAI that would fit 2001-2004 becuase they have a completely different air box configuration so that space that the CAI would go into is very different.
Forgot to mention that the dyno is from a Hyundai...that is frightening...if this fits a 2004 TL so well, why not show a TL dyno??
Old 03-30-2004, 05:25 PM
rynpamn21's Avatar
Thumbs up
good point....this is the kind of answer that i was looking for...i guess i will have to shell out another 150 bucks to get the INJEN...
Old 03-30-2004, 05:58 PM
On the way!
fla-tls's Avatar
Man, for $79 I was expecting to see a dryer hose and some tie wraps....
:smackhead
Old 03-30-2004, 06:56 PM
apwalsh's Avatar
Not really. The 04TL has a vent that cools off the hot air in the engine compartment with the outside air rushing in. A CAI takes the air from outside the engine compartment before it gets to the hot air inside.
Anyway, I would rather spend the money and get the real deal that even think about that $79 dollar job.
Old 03-30-2004, 07:49 PM
caball88's Avatar
how much "colder" is an aftermarket intake compared to the stock cold air intake. i know the stock one doesn't draw air directly from the front bumper but i think its cold enough. is the 1-2 peak horsepower at 5K rpm worth it? what about water ingestion? that would really "suck".
Old 03-30-2004, 08:40 PM
apwalsh's Avatar
I'm not an expert on this, but I think the HP gains are significantly higher than 1-2. The dynos show more like 11-15. There is also a release valve (seperate purchase) for the intakes that will remove the water properly. I've also know people with similar intakes and I've never seen or heard of a water ingestion problem. I think you'd have to drive through a large puddle to actually take on enough water to damage the engine.
DerrickW
11-15-2015 05:52 PM
CAgine
10-28-2015 04:31 AM
lanechanger
10-13-2015 10:56 AM
swany0095
2G TSX Performance Parts & Modifications
10-07-2015 02:18 PM
h22lude
09-27-2015 06:22 PM
Quick Reply: CAI for 79 bucks?
