A/C with high mileage
nope after 76894 miles it only produces warm air, after 107895 miles it only produces hot air
seriously though, with normal maintenance the A/C should be working as intended for unlimited miles
To fix an A/C system can cost as high as $1500/2000 to do a repair, but it is maintenance free and most need no service. We have an '89 vehicle we purchased new and with 198,000 miles it blows as cold as when new and has never needed any service. Actually with all the vehicles we've ever owned, and there have been many, the only ones that have needed service have been 3 Jeep Grand Cherokees as the evaporator rots, leaks, then needs replacement.
Bottom line, not a common occurrence with the TL.
if it loses cooling abilty it has a freon leak or system problem- get it ck'd
Older systems may need a few ounce top off -
must do pressure testing before such thing is attempted-
NOT for the untrained- death or damage to you and the car are possible--no kidding!!!!
DO change you cabin air filter annually-easy DIY, filters avail at parts stores with charcoal or antibacterial agents added are great in my opinion
vacuum out the leaves and debris while there
from my gen2, guessing gen3 may have same issue of too short a length power lead to the blower results in connector strain and heat damage,,a burning plastic smell you will never forget
My 04 has 93K on it now and the A/C still blows out ice cold air. The only problem I have with it is a farting noise that it makes every time I shut off the car. Hopefully acura can figure it out the next time I'm there.
Biggie_B
May 27, 2025 05:51 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
I'm only at 40K, and blows cold!
As mentioned in my above post, the dealer must've liked my sister.
