C-026: DIY Changing ATF (with Pics)
Old Jun 20, 2013 | 08:06 AM
  #201
gwdew's Avatar
Originally Posted by gwdew
Hey guys need some advice...
I broke the bolt towards the front of the car (damn saltly NJ roads) that holds the plastic covering the transmission. It broke halfway down the shaft. I'm afraid to drill out because if my drill bit "walks" I could be eating away at the aluminum threaded frame.
Any suggestions?
Thinking of bringing it to a garage so they can do it. But, I hate to spend the money!
<a href="http://s1273.photobucket.com/user/free12day/media/page_zps986f08f9.jpg.html" target="_blank"><img src="http://i1273.photobucket.com/albums/y420/free12day/page_zps986f08f9.jpg" border="0" alt=" photo page_zps986f08f9.jpg"/></a>
Old Jun 20, 2013 | 08:10 AM
  #202
gwdew's Avatar
^what bolt did you break? pics would be helpful, as we can't just read your mind.
Old Jun 20, 2013 | 08:11 AM
  #203
gwdew's Avatar
[IMG][/IMG]
Old Jun 20, 2013 | 09:04 AM
  #204
SharksBreath's Avatar
BANNED
shit dude, just rip it out (the entire plastic frame) there are enough other supporting bolts/clips to hold it back in place after you're done the drain and fill.
OR try and slide it out of the way enough to where you can still drain the fluid.
Old Jun 20, 2013 | 09:10 AM
  #205
hondaracer4vtec's Avatar
8th Gear
Very nice write up.
Old Jun 20, 2013 | 09:32 AM
  #206
gwdew's Avatar
I changed the trans fluid already, that wasn't a problem. I'm just worried that the wind will get it and rip it off while my wife is driving. Then I'll get the call with her crying and telling me to take it to the dealer next time.
I have a ziptie on it now
Old Jun 20, 2013 | 09:35 AM
  #207
BANNED
you'll be fine man.
Old Jun 20, 2013 | 10:27 AM
  #208
aIRpeACE's Avatar
good job. thanks
Old Jun 20, 2013 | 10:30 AM
  #209
BANNED
^you're very welcome.
Old Jun 24, 2013 | 01:22 PM
  #210
vkick's Avatar
Originally Posted by LivingLarge
Just wondering if anyone tried the following tool to extract transmission oil from the dipstick hole. If so, can you get 3 quart of oil out?
http://www.griotsgarage.com/product/...d+extractor.do
I did my 3x3 in 1 day. I tried pumping through the dipstick and got 2.5 quarts. I also tried draining it and got 6 quarts instead of 3. Does anyone know why?
Old Jan 24, 2014 | 11:07 AM
  #211
RJANACONDA's Avatar
Registered TL Lover
Exclamation drain bolt pics DO NOT APPLY to 04
the pics are great and everything was going good till I got completely frustrated and wondering if I was in the wrong location after not being able to find the drain bolt for 30 min. going from the computer to the car and getting pissed. the bolt on the 04 is on the OPPOSITE side and faces in towards the car here are pics for anyone with an 04 as far as fill bolt I was able to get to it just by loosening the fuse box by removing only the two mounting bolts and using 2 extensions. car is on rhino ramps and draining now I am hoping I only get 3 qrts a drain I only bought 9.
Old Jan 24, 2014 | 11:17 AM
  #212
RJANACONDA's Avatar
Registered TL Lover
I am changing from oem to after market and the oem fluid is REALLY nasty looking, (i am wondering if it was actually done last time, i was overseas...) i will be doing a drain with every oil change from now on but should i do all three drains today a couple of people have said its better to drive it 100 miles in between each...
Old Oct 29, 2014 | 08:39 PM
  #213
mattpete's Avatar
so I just did this but 4 quarts of fluid came out... Yes I know I checked it like 5 times because I thought I was crazy. Same thing on our MDX. 4 quarts came out so I put 4 quarts back in. Level is just above the top dot on the dipstick but that's in my semi-level driveway. I've been driving the TLS for a week and have not noticed any issues and I drive a good 100 miles a day AVG.
I think I need to find a level spot and check that isht again.
Anyone else have this experience with AT on a TLS?
Old Oct 29, 2014 | 08:40 PM
  #214
mattpete's Avatar
awesome write up too btw OP - thank you
Old Oct 26, 2015 | 08:49 PM
  #215
jaredb03's Avatar
Can anyone recommend a good way to remove a small amount of fluid. Mine is just a little high and i don't think pulling the plug and trying to get it back in before to much came out would work out.
Old Oct 26, 2015 | 10:53 PM
  #216
Majofo's Avatar
Just loosen the bolt (don't remove) and let it drip out what you want to remove and tighten up after.
Old Oct 27, 2015 | 09:08 AM
  #217
polobunny's Avatar
Registered Bunny
Second Majofo. Loosen it almost completely until there's maybe a turn or half a turn left, let the bolt hang there, enough liquid should drip that it won't take you too long but you can tighten it when needed.
Don't forget to clean the bolt after tightening it up.
Old Jan 16, 2016 | 10:48 PM
  #218
imJimmyToo's Avatar
5th Gear
The pictures really helped man!
Old Jan 17, 2016 | 01:20 AM
  #219
doggydog's Avatar
Always remove ATF fill bolt before removing drain bolt and draining out yout ATF.
Old Jan 17, 2016 | 08:19 AM
  #220
b15's Avatar
b15
This is true for an MT, transfer case or differential fluid change, but not big deal on an AT. I just fill it through the dipstick. Most AT cars don't even have a fill bolt plus I bet mine is probably seized considering its a 2006, don't care to find it either
Old Apr 2, 2016 | 11:56 PM
  #221
Bradford Plummer's Avatar
Talking Automatic Transmission Fluid change
I drained my 2008 TL S tranny fluid and I got 4 quarts. Filled it up with 4 quarts of AMSOIL and it's running well. I am going to do the second drain next weekend and third the weekend after that.
Thanks for the post and pictures. It helped a lot.
Old Jun 22, 2016 | 04:30 PM
  #222
ZeeJM's Avatar
I just completed Round 1 of 3 on my 2006 5AT at 100100 miles. I'd share pics of my old fluid but I don't want anybody getting violently ill...
I used one set of Rhino Ramps on the front wheels only without jacking up the rear at all. I got out almost three complete quarts of the old fluid through the drain port. I also found the 8 inches of additional clearance provided by the Rhino Ramps was enough for me to get under the front of the car and deal with the plastic shield (do order yourself a bag of new retainer pin/fasteners from Amazon) and access the drain plug. Per some of the earlier posts I only loosened the rear10mm bolt on the plastic shield and then just swung the shield away from the drain pan and bolt.
I also went "old school" and drove the car around my town after adding new fluid. I'm noticing much smoother shifting even after just the first of the three drain and fill cycles. I'm using Red Line D4 ATF.
Old Jun 23, 2016 | 11:14 AM
  #223
BreezyTL's Avatar
Finally got all the parts I need for mine. This weekend mine will get a full treatment at 196k miles!
New Trans Filter/Spring
New Pressure Switches
3 Qts of Redline D4 - (Drive it a couple days and repeat 2 more times.)
Old Sep 28, 2016 | 12:27 PM
  #224
tldrummer89's Avatar
Got it!
Doing it this weekend
Old Sep 28, 2016 | 12:49 PM
  #225
Originally Posted by tldrummer89
Got it!
https://acurazine.com/forums/3g-tl-p...-08-tl-840630/
Old Oct 2, 2016 | 09:51 AM
  #226
ATN's Avatar
ATN
Guessing the pictures aren't available anymore?
Old Oct 2, 2016 | 03:15 PM
  #227
peter6's Avatar
RJANACONDA post pictures how it looks under the car (which bolt to look for). It is under plastic cover that is held by 3? bolts.
And this is bolt that you need to remove to fill transmission with new fluid
Old Oct 3, 2016 | 12:36 PM
  #228
coltlauer's Avatar
Living it up TL style
If it helps anyone when i did my ATF I used D4 as recommended by Acura and found that i didnt even need to remove the fuse box with use of a flex socket and the funnel i bought at O'reillys that had the 3 foot bendable hose. It definitely made the drain and fills a breeze. it took me about 4 hours to do all three drain and fills with these tools considering the lack of me not having to remove a lot of parts from the engine compartment.
nanos
Nov 12, 2015 08:41 PM
Skirmich
Sep 15, 2015 06:41 PM
mc1114
Sep 11, 2015 05:50 PM
Aleax
Sep 11, 2015 11:31 AM
gqdabien
Sep 8, 2015 11:41 PM
