Broken bulb in driver side map light.. Now what??
Old Aug 28, 2006 | 11:05 PM
Wooo Haaa's Avatar
Arrrrrrrrrrrrrrrrrrrrrgh
Was trying to take out the map light bulbs and ended up breaking one of the bulbs. How do I get the part of the bulb which is stuck inside? There isn't anything sticking out to grab hold of.
stooooooooopid I know but help a brother out!!!
Old Aug 29, 2006 | 12:01 AM
frenchnew's Avatar
first things first, remove the fuse for the map lights so has to prevent from shorting out the circuit and burning out the fuse. Fuse # 6 , 7.5 Amps located in the fuse box behind the driver's side kick panel.
You might have to reprogram the HFL
Next , get a pair a gloves to prevents cuts and please wear safety glasses.
I would suggest to use some kind of dental picks to pry the remainder of the bulb out carefully.
Try to work slowly and if you have the use of a vacuum cleaner, use it while you are trying to get the base of the broken bulb out so as to prevent pieces of glasses falling everywhere.
Best regards
frenchnew
Old Aug 29, 2006 | 08:38 AM
NSXNEXT's Avatar
You do not have to remove the fuse. Just make sure the map lights are OFF. Use a pair of needlenose pliers and pull it out. Make sure to grab the metal base.
I would put a towel down under the light to catch any glass fragments that might fall out.
Old Aug 29, 2006 | 09:17 PM
Wooo Haaa's Avatar
Best regards
frenchnew
Thanks everyone. The dental picks did the trick!!!!
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
acuraST
Sep 17, 2015 02:31 AM
hand123
Sep 10, 2015 09:27 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
