Brembo rotor question?
Old 02-07-2010 | 12:35 PM
ridenfish39's Avatar
I tried to search but didn't find anything........
Will rotors that fit the Brembos on a 6mt TL fit a Type S AUTOMATIC?
Old 02-07-2010 | 01:31 PM
cschell's Avatar
Yes, believe they use the same braking system
Old 02-07-2010 | 01:32 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Absolutely.
Old 02-07-2010 | 02:06 PM
I know that they are the same calipers but I was not sure if the rotors were exactly the same.
Old 02-07-2010 | 02:15 PM
BradE's Avatar
Yep, they are the same rotor.
Old 02-07-2010 | 04:13 PM
01tl4tl's Avatar
if the automatic came with the single piston calipers in front- the brembo rotor is 1 inch larger diamter than the stock one
example- trying to upgrade to brembos from single piston requires different steering parts for clearance on larger rotor and have to make sure your rims will clear the larger calipers
Old 02-08-2010 | 12:40 AM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
Ok thats a lot of extra info but he said type S automatic which has Brembos so the answer to his question is yes they will work.
Old 02-08-2010 | 03:22 AM
01tl4tl's Avatar
Im a gen2 and dont know which gen3 model has what equipment - so I pass on info I do know for fact -like upgrading from the single piston of early gen3 to brembos or wilwood is doable but costly
Old 02-08-2010 | 10:10 AM
TonemanTLS's Avatar
LUV MY 2007 CBP TLS
yup the same
06TLMatt
10-02-2015 08:14 PM
Lucrativesoldier
09-28-2015 03:47 PM
TL-GIXXER
09-18-2015 10:25 PM
datadr
09-12-2015 09:12 PM
Quick Reply: Brembo rotor question?
