Brembo Brake Pad Change - Massachusetts
A-Spec'r
Hey All-
Has anyone out there have their Brembo Brake Pads changed by a local mechanic they would reccommend in the Massachusetts area? I am looking to have mind done very soon, but don't really want to take it to the dealer or is there a reason i should take it to them?
Thanks in advance for the thoughts -- Rob
All About Trance
Brembos are one of the easiest to change. I'm not that mechanically inclined and I was able to do them with the help of this forum and a friend. Basically, once you take off the wheels and pop out the pins on the calipers, you can pull your old pads out and replace them with your new ones.
This is the thread I had used for reference.
https://acurazine.com/forums/showthread.php?t=119423
TYPE-S CBP MT
it is very easy to change... just read that thread... and you will save some money doing it yourself...
by the way, i just came back from boston for the long weekend... Great place great food... great road trip
Let's Go Pens
I had never done my own brakes before... A few months back I decided to tackle this project and I couldn't have been happier. I will see if I can locate the original post which included a detailed explanation and step-by-step instructions for any novice to follow
Edit: Just found the link: https://acurazine.com/forums/showthr...21#post1966921
Hope this helps with your project!
Resurfacing or replacing the rotors is a good idea if you want to minimize the potential for brake noise.
A-Spec'r
Thanks to everyone for the quick responses.... it sounds like most folks that have changed the pads themselves are very happy.... what pads & rotors did you guys end up doing? I may be up for trying this myself....
All About Trance
You mean to push the calipers back in? If so, then you can buy the C clamps, but others, including myself, have just used screw drivers to push them back in. Just make sure you have the master cylinder clutch fluid open because it'll make it a lot easier to push back in.
Do It Your Self Can Save Money
Hi everyone, I agreed “illstrategy”, changing brake pads by yourself can save money… I tried it last month I thought it is so hard but I just read the manual that include in the box I ordered and it so easy. Try this one I hope it can help you changing brake pad set.
mada51589
05-03-2022 08:54 PM
