Brakes
Brakes
I was changing my brakes today and when i finished, put the master cylinder cap back and was ready to go for a spin. but my car is stuck.. its like the brakes are seized now..
I didnt tighten the caliper bolts super tight. Im wondering if the rotors i got are thicker and that might be the problem? no idea.. anyways.. i searched came up with like 300 different posts all not brake related.. search option noob i guess..
has anyone ever had this issue before? 3g TL base
What did you change, rotors, pads, front, rear? Pistons go in easily?
Jack it up and try and turn each wheel to see which might be the problem.
There shouldn't be any reason to have wheel(s) locked up after a pad change, if no problems encountered.
Rear pins have flat spots that need to be vertical when calipers installed or they can bind.
only front pads and rotors changed, plus cal piston bushing.. the piston went back in with c clamp and old pad as pusher.
the rotors spin when i dont have the wheels on. the drivers side grinds a bit. passenger doesnt move in Drive unless i step on the gas a bit.
as soon as i had the wheels back on it wouldnt move at all.
gonna tackle it again in the morning...
TL brakes 1 Me 0
TL brakes 1 Me 0
Seems like a weird symptom from a standard brake change. when I re read ur first post I noticed u said caliper piston bushing... It's gotta be related to that. Some way or another.
Unless u got thicker rotors somehow but that's probably less likely.
My money is on the caliper bushing
TL brakes 1 Me 0
TL brakes 1 Me 0
If so, but when on the ground, car wouldn't move?
Sure emergency brake off?
the wheels did not turn off the ground with wheels installed. only without the wheels on the rotors spun but not freely at all..
the caliper bushing doesnt look to be more compressed than normal.
i took off one of the rotors and put everything back together last night from scratch and even with the original worn out pads and rotors the car still wont move wtf.
bled the brakes and finally got the rotors to spin freely no problem.. the main issue is caliper clearance on my wheels.. the spokes are rubbing against the caliper causing the seizing. +27 ET on all of them and a big fuck you to me.
Stay Out Of the Left Lane
So you are using the same wheels before and after the brake work? There was no rubbing between the caliper and the inside of your wheels before but there is now after? Something doesn't seem right here.
my other wheels the ones that rub are 18x9 even with a hub spacer.
just took it for a quick spin in the neighbourhood and everything is normal.
Ok, changing of the rims was an important missing detail. So did your "other wheels" ever fit properly and not rub?
when i installed the aftermarket wheels.. i noticed the gap between the caliper and wheels was fairly small and tight like a chinese virgin. but it didnt bother me since there was no rubbing at all at the time.
after installing the rotors and pads the caliper had expanded the width thus deleting whatever gap was left.. like 1.5mm literally.
That being said. i just transfered the 18's to my moms civic and they work fine on her car wtf. but i told her she had to pay me 1000 bux if she wants them to stay on lmao.
when i bought the car the brakes were going(16'' steelies when i bought it).. so last night i decided to finally change them since im going on a 400km road trip next weekend with some friends.
Good luck with your Mom
ill throw some pictures up soon of the damage the caliper caused my 18" wheels. needless to say ill be calling the guy who told me they would fit. he owns a tire shop.. he ordered them for me and said theyve fit plenty of TL's in that size wheel.. which is bs cause this thread just proves it doesnt. back to stock for now.. might sell the car.. found some rust on the rear 1/4 beginning to surface as well on the inside of the well. .. and now im completely livid about it.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
