brakes
Old 12-09-2009 | 01:39 PM
108tls's Avatar
brakes
well, my 08 tls has 27k miles and is ready for pad replacement. want to find out from ppl who have experience changing their own pads.
is it absolutely necessary to resurface the rotor? 1st brake pad change and my rotors are not warp in anyway but there is a light grove starting to appear at the very inner edge of the rotor, if so i will have a machanic who is a friend that will charge me $120.00 labors to install and resurface the front rotors and brakes.
what do you guys think?
thanks in advance for your input and response.
Old 12-09-2009 | 02:30 PM
BigJack75's Avatar
I have read on here that if the rotors are not warped turning is not nessesary. Just put some new pads on and bed them down good. That is what I plan on doing when the time comes. The price you got quoted sounds pretty good but what pads are they putting on?
Old 12-09-2009 | 02:45 PM
BradE's Avatar
If they aren't warped, then you don't need to resurface the rotors. Clean em up and remove any glazing and pad material.
The pads are so easy to change it's insane. You remove 2 pins, take the old pads out, put in new, replace the pins. The caliper doesn't even need to come off. It takes longer to get the front of the car jacked up and on stands than it does to change the pads.
N.I.toHTown's Avatar
You dont need to machine your rotors. Unless you have somehow warped them (which you havent) they should be fine. Your friend is charging you a lot! You should be able to do your brakes yourself in a couple of hours if it is your first time. check the garage for advice and walkthroughs.
I did my front pads for less than $50 6 months ago.
Old 12-09-2009 | 03:13 PM
108tls's Avatar
i plan on giving the cmax gold from autozone for $60.00 a try since that seems to be a pretty positive feedbacks on this forum.
Old 12-09-2009 | 03:19 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
I know the OEM pads are more expensive, but that is what I recommend you use. Yes, they create a lot of brake dust, but they perform exceptionally.
If cost/brake dust is a concern then you can go for alternatives, but the OEM rotors work the best with the OEM Brembo pads.
Old 12-09-2009 | 04:09 PM
piggydog's Avatar
don't even need to jack up the car. I just turn the wheels, 2 pins on each side. Watch out for the lever/spring in between the 2 pins. Once you pull out 1 pin the thing might come flying off. Almost got a good black eye from it.
Old 12-09-2009 | 04:22 PM
Rafiton's Avatar
Damn I had to do my brembo change at 15k the rear im almos at 20 and I already bought them. nad im sure that at 24-26k the brembos will need to be change again.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
rockyboy
10-02-2015 10:45 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: brakes
