Brake Pads
Team SSM Queen
Brake Pads
My car is almost 5-1/2 years old, 84,000 miles, and I'm still on the original brakes. Every now and then the front brakes squeak, should I replace the pads?
I can't do this myself, so I was wondering if it's ok to just use a local mechanic rather than the stealership (I would buy OEM pads and have them install them). Is there anything special they would need to know about Acura brakes when they install the pads? And do the rotors need to be resurfaced when you replace pads? Thanks!
I'd say your probably overdue to replace the pads.
Yes, you can buy the OEM parts and have another mechanic do the work.
Have the mechanic inspect the rotors to see if they need resurfaced or replaced.
Pads may occasionally squeal if dust or debris gets caught inside. You only need to replace the pads if they worn to the service limit or sqeal/vibrate consistently. If you don't know how to check the service limit, have a professional do it for you (or search on here for the step-by-step). Even if they sqeak occasionally, they still may be good. I have an 03 Honda Element w/ 80k miles that's still on it's original pads. They still have pleanty of thickness left.
BTW: Good job asking. Squealing or low brake fluid light is the first indication that your pads are wearing thin. Never top off your brake fluid if it's low. This is one of the warning signs, and you should have the system inspected if the fluid gets low...
Team SSM Queen
Thanks for the replies guys -
When my Dad taught me to drive, he told me to step on the brake like there was an egg underneath, maybe that's why my brakes have lasted so long.
j1n do you have Brembos?
My dealer quoted me at $679 for front pads and rotors /w labor!!!!!
I'm at $50k... first time it is being done I think ( i bought it @ 34k)
Definitely won't have them do it, but should anything be under warranty??? perhaps the rotors?
Buy the OEM pads yourself and call up a place like "Brake-Team" to see how much the install would be. You don't really need to resurface the rotors unless your getting shaking/vibratoin during braking, though they may tell you it's a must anyways...
PS: OEM pads include all shims and caliper grease. You should also get the caliper hardware kits as well (springs & slide-plates). This way there should be no additional parts required (provided rotors and calipers are in good shape).
For AT you need:
- 45237-S0K-A01 front pad retainer (x4 @ $3.50 each)
- 45022-SEP-A01 front pad/shim set (x1 @ $42.71)
- 43244-SG0-003 rear pad retainer (x4 @ $5.04 each)
- 43022-SEP-A00 rear pad/shim set (x1 @ $46.31)
Total parts price: $123.18
Prices are from AcuraOEMParts.com
When you buy from excelerateperformance.com or heeltoeauto.com, both the rotors and pads, do they come with the retainers and shims or do i have to get them from somewhere else? Thanks!
As the pads wear, the piston(s) extend farther into the bores so the fluid level will continually drop, indicating the wear, but it is always a good idea to keep the reservoir, near, or at the full mark. As some reservoirs will hold more fluid than others, you don't want to chance running dry, and there is no way to measure exact pad wear with the fluid drop, so inspection is always the best method.
To add to previous post: Low fluid is a good warning sign for you to check your brakes, and is the reason I recommend not topping off the fluid. If you look in your Owners Manual, you'll see that they don't recommend topping off either. They just say to have the brake system inspected if the fluid gets low...
Q('.')=O
Question: Has anybody ever gone to Just Brakes? $99.99 for new pads and shoes and they machine rotors and drums and have lifetime warranty...
My brakes are starting to squeal more and I might need to replace them soon also. 66k on my car.
Yes, I got rear drums done on my Civic. They do decent work. $99 is including aftermarket pads and hardware. Personally I would buy OEM pads and hardware, and just bring them in for their labor if I was unable to do the work myself. OEM parts are extremely high quality, and made by the same company as the caliper they go in (Nissin, Akebono & Brembo)...
Q('.')=O
^ Thanks for info. And I assume these are the things I would need to bring them?
For AT you need:
went to just brakes for 99 and they voided the lifetime cause i didn't replace rotors/calipers on my 98 accord....due to the condition of the rotors/calipers the brake pads were going to wear out sooner so they voided the lifetime thingy....oh well. don't have the car ne more
went to just brakes for 99 and they voided the lifetime cause i didn't replace rotors/calipers on my 98 accord....due to the condition of the rotors/calipers the brake pads were going to wear out sooner so they voided the lifetime thingy....oh well. don't have the car ne more ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Originally Posted by Cerezo
Are the retainers required? Not sure what they are.
![](http://www.acuraoemparts.com/delray/jsp/catimgs/14sep4_b22.gif)
![](http://www.acuraoemparts.com/delray/jsp/catimgs/14sep4_b1910.gif)
08_UA7_Gr33k
02-11-2016 02:17 PM
2004, 43022sepa00, 45022sepa01, acura, brake, element, honda, limit, manufactures, number, oe, pad, pads, part, wear
